Home > Puma (Tdci) > leaking tank
MK
leaking tank
I think this topic has been posted already. After filling with diesel I got a leak I´m quite sure it comes from the upper part of the tank and for sure not from the infilling tube.
Is the only solution to remove it for inspection? Any hatch?
cheers Puma 110" SW
Post #401313 23rd Feb 2015 12:36am
T1G UP
i've just done mine. the ring that holds the sender unit into the tank had come loose.
easy to do.
jack it up, rear wheels off. tow bar off , undo the fuel filler pipe, undo the front of the tank guard, drop the tank enough to get your hand in and un pop the flow and return lines and the sender wiring. then undo the guard rear nuts in the x member and drop the lot on the floor. clean everthing and then do the ring back up...hard going because the senders spring loaded.
Post #401316 23rd Feb 2015 12:48am
MK
Thanks a lot Thumbs Up Puma 110" SW
Post #401318 23rd Feb 2015 12:51am
munch90
Breather pipes split on top of the tank
i think depending on year there are two , one small and a large one
very common for them to split
do a search on forum for tank breather
Post #401329 23rd Feb 2015 6:46am
davew
You might want to consider making an inspection/access hatch - you don't need to remove the tank to create one. There are a few threads on here showing different ways to do it and cover it. http://www.yorkshireoffroadclub.net/
Post #401361 23rd Feb 2015 10:28am
