Home > Td5 > Security
Ofender 130
Security
Hello All,
First post, I have a td5 hi cap with a quadtech ( just fitted ). I've noticed a lot of attention from the travellers, I've fitted a pedal lock, ignition lock upgrade from ex engineering, is it worth fitting a VHF tracker ? Any other ideas out there,
Photo before the quad tech and fully loaded.
Question
Post #400876 21st Feb 2015 6:03pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Post #400880 21st Feb 2015 6:11pm
gilarion
Personally I believe the more security devices fitted the better and a tracker is a must even if it is one of those cheaper ones from eBay, which incidentally are very good.
http://www.ebay.co.uk/itm/Realtime-Vehicle...1e7fdfe73a For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #400892 21st Feb 2015 6:37pm
Green Machine
X-Eng transmission lock is a good shout for Td5. Compact to carry around in cubby box and easy to deploy / remove once you get the knack. Combined with a good pedal lock makes for pretty robust locking of the transmission (at least from the cabin). Also it's bright yellow and right in view through the window, so nice visible deterrent. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #400900 21st Feb 2015 6:55pm
there you go ...
if you are leaving it for any length of time, take the steering wheel off
outside light with motion / IR detection (and webcam)
some trackers have tilt / knock sensors, electronic fences
disklock / chain car to immovable object (concreted in hoop)
list is endless ....
Post #400903 21st Feb 2015 7:02pm
Ofender 130
Security
Thanks for the info. Tracker looks next,
Post #400923 21st Feb 2015 7:27pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I have that exact tracker, it is good however it drains approximately 2.5ah per day which is a lot! You could have trouble starting after a week when you include the vehicle's alarm system and cold weather.
I've also noticed sometimes it can give false reports when surrounded by buildings... I had a big fright one night in Glasgow when it text me to report that the vehicle was moving at 28mph over 2 blocks from where I parked it. I requested a location reading and it text back it's location being 2 blocks away again and it was doing 20mph... I freaked out. Then after a 3rd location reading I noticed the car was in different location from the first 2 texts which was impossible to do in that amount of time.. after another check it gave the same place as where I'd parked it and 0mph. Increasing the movement alarm from 200m to 400m sorted all this out but what a frighting experience to have at 4am 1st of Jan when you are drunk.. Mr. Green
The best GPS solution is an old smartphone with a new battery, much more accurate and you also have it as a backup phone in the car..
Post #400961 21st Feb 2015 9:00pm
Ofender 130
Interesting about an old smart phone, well hidden, powered up.would the police chase if you told them its on the move?
Post #400967 21st Feb 2015 9:12pm
VeeTee
Netherlands
^^^ Why not? A GPS with a GSM module (i.e. a tracker) is the same as a GSM with a GPS module (i.e. a smartphone)... Shocked Question Cheers, Vincent
MySite
Post #400972 21st Feb 2015 9:21pm
