Home > Technical > Help ID a bolt I think is the panhard bracket to chassis
Welkman
Hi, fitting steering guard and removed/broke the bolt aft of the tie down bolts which I believe holds on the panhard bracket to the chassis. I could be wrong! I have measured it at about 155 mm and 12 mm diameter. It is threaded for about 35mm. Does anyone know the part number? I need to order two of them.
Many thanks
James
Post #400597 20th Feb 2015 2:48pm
Cupboard
This may be a silly question, but can't you just replace it with a non-Land Rover bolt?
The head of it should tell you the grade and if it's metric, then just buy one of the same grade and dimensions and away you go.
Post #400599 20th Feb 2015 3:06pm
bob neville
FC112326 ??
http://landrover.shukersparts.co.uk/bolt-1-2unf-fc112326.html
2013 Defender 90 CSW - sold
Post #400603 20th Feb 2015 3:20pm
Martin
Site Admin
They are 1/2" UNF bolts, not metric
253948 is 1/2" UNF x 6 1/4" -> roughly 12mm x 155mm  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #400648 20th Feb 2015 5:35pm
Welkman
Thanks guys. The bolt says 'AA' on the top and it all makes loads more sense now I know its not metric Smile
Post #400661 20th Feb 2015 6:29pm
