Home > Wheels & Tyres > Flat tyre
derek
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Flat tyre
Got a flat the other day so got it checked for free at kwik fit turned out to be leaking from rim.
As the alloy corrodes it causes slight leak cheap to fix and saves getting new tyre
Post #399235 16th Feb 2015 10:36am
Bead sealant Whistle
Post #399238 16th Feb 2015 10:54am
munch90
just make sure they wire brush it off before sealing
lots of tyre places just paint sealer over the top and they start leaking again
another minus for pressure washing , the high pressure forces water between the tyre bead and rim
Post #399240 16th Feb 2015 11:02am
Cuthbert
Personally I stopped going to Kwik-Fit many years ago.
The outlets I dealt with seemed to have a policy that if you went in with say a flat tyre, they would offer a free vehicle inspection and 10 minutes later - have you noticed your other tyres are worn? ..... and the shock absorbers are tired? .... and your brakes are needing replaced? .... and that exhaust might benefit from replacement? ......... and if your head really does button up the back ...... we have a 'managers special discount today' ....
Two weeks ago I bought tyres at my local independent dealer ...... he had a new employee who was ex-Kwik-Fit and his opinions on his former employer and their current business model were not very positive.
Post #399409 16th Feb 2015 7:36pm
Blondie
Dont get me started......!
I was told by Kwik Fit that fitting an inner tube to "tube type tyres" was illegal and I could be prosecuted.....! They dont want to repair tyres only sell new ones.
Post #399420 16th Feb 2015 8:05pm
JWL
I had to rescue a previous car from one of their de-pots when my now ex-wife took it to them for an MoT. They had it up on the ramp and started spouting at her that it was completely unroadworthy, tyres were shot, the brakes were non-existant, the exhaust was falling off....... the list went on and on. She had phoned me in tears as she had our two small boys with her and was having a bad time with them.
They had only put it on the ramp and not even laid a spanner on it to have come to that diagnosis, when I got there they wouldn't let her leave untill she agreed to the work needless to say that they didn't stand in my way when I politely told them that I was taking it off their premises.
I took it straight round to my usual garage and half hour later had a new MoT on it after changing a brakelight bulb. the tyres were less than 6 months old, I'd put new pads all round the week before, the exhaust was never changed and lasted another 3 years and 50K miles. I did talk to Trading Standards afterwards but because I had walzed in and taken it away without getting it inspected there and then there wasn't a lot that they could do apart from logging it on their system to join with the other hundreds of complaints they had there allready.
Post #399452 16th Feb 2015 9:33pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I used kwik fit for a while for MOT's as somebody told me the don't know anything about cars let alone land rovers and can not count. So several years I got my MOT while having an td5 is a 1984 90 with has on paper a 4 cyl diesel engine, Whistle
Now my 90 is 90% td5 only some body parts are from different ages. Mr. Green Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #399535 17th Feb 2015 8:09am
MartinK
My old Disco2 developed "porous" rims. I ran it (pumped-up every few weeks) until the old tyres were on their way out, and then had the wheels blasted, re-painted new tyres, balanced etc...like new Smile
If one has gone porous, then the rest may not be far behind... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #399554 17th Feb 2015 9:40am
I have never used Kwik Fit myself (the name is enough to put me off) but deceided that I never would under any circumstances when a bloke I used to work with took his (slightly unusual) Ford Escort in for a new exhaust.
KF then proceeded to cut the old exhaust off, then found that (a) they didn't have a replacement, (b) they couldn't get a replacement for at lesat two weeks, and (c) the old one was by now in the skip and not refittable.
Cue one very unhappy customer!
Post #399558 17th Feb 2015 10:11am
Cuthbert
Not exactly a glowing testimonial for how to attract and retain customers?
Post #399884 17th Feb 2015 11:42pm
