Home > Technical > New battery - recommendations please...
Tiger
Need a new battery, not bothered about extreme winching, deep cycle, works upside down glass mat.
Just after a decent quality good value battery?
Td5 if that makes a difference Thumbs Up
Post #398678 14th Feb 2015 10:44am
mk1collector
Try get a Delphi like the original as they last for years Thumbs Up
Post #398680 14th Feb 2015 10:46am
munch90
any branded are roughly the same
exide , varta , bosch ,
normally best advise is go for the longer warrenty models
Post #398682 14th Feb 2015 10:49am
Alex1976
I have a Bosch S5 Silver Calcium in my 90 for the last 3 years. It has a five year warranty and still going strong. I have quite a few extras (heated seats, screen etc) and this doesn't seem to trouble it. They are well priced too.
Post #398684 14th Feb 2015 11:00am
landroverdiver
Just been through this, I eventuall plumped for a Yuasa from Halfords. I could probably have saved a few quid going elsewhere, but didn't have the time.
The posts are reversed from the original and I had to make a new angle bracket to secure it.
Odyssey seems to be highly recommended.
I put an Optima in a previous defender and it was no problem.
Post #398686 14th Feb 2015 11:06am
ibexman
OE battery is now a Varta
Post #398689 14th Feb 2015 11:15am
Tiger
Feeling lazy, any direct buy links?
Anybody tried these guys ?
Reviews look okay but always suspicious Confused (Never heard of "Enduroline")
http://www.tayna.co.uk/069-Enduroline-Car-...P8384.html
Post #398690 14th Feb 2015 11:17am
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Worth reading this article from A&N. You might then go for the Bosch S5 as recommended above
http://www.aandncaravanservices.co.uk/battery-technology.php
Post #398704 14th Feb 2015 12:37pm
gilarion
The only benefit you get with Branded batteries is a longer guarantee, which to be honest is not sometimes worth the paper it’s printed on, try taking a Varta or similar three year guarantee battery back after two years and you will see what I mean, and the premium you pay for the extra years guarantee is ridiculously high. All batteries sold in the UK carry the same British Standard specs.
I always buy my batteries from ManBat, who incidentally make all the batteries for Halfords, who then add their guarantee premium. However if you buy direct from ManBat they are thirty per cent cheaper.
In any respects it is not the make that is so important, nor the cranking amps, the power generated by the battery when the ignition key is turned, though obviously the higher the cranking amps the better, it is the cold cranking amps that you should be concerned with when the weather is cold and there is more strain on the battery, buy a battery with the highest cold cranking amps you can find and it will not let you down even on the coldest of mornings.
Also worth considering if you do not use the Land Rover regularly is the new style of battery that is fitted to Campervans that gives both high cranking amps but slow discharge rates, this means that if you do not do a high mileage the battery will not go flat as fast as standard auto batteries. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #398708 14th Feb 2015 1:11pm
Dave-H
Use them all the time, reliable company. Thumbs Up
I always think the 069 is a little under gunned on a Landrover ....
Can't go wrong with this one, deep cycle and under £90 delivered to your door Cool
http://www.tayna.co.uk/Numax-CXV30HRMF-P3673.html Guns and Landrovers .... anything else is irrelevant.
Post #398726 14th Feb 2015 2:34pm
Laurie
Batteries with a two year guarantee usually last, err, two years.
Post #398733 14th Feb 2015 3:05pm
munch90
I agree a 069 wont have much back up for a defender
Post #398742 14th Feb 2015 3:27pm
ericvv
My original factory Varta battery had a zero years guarantee I think, as it is considered a consumable by LR. Now after 6 and a half years and 72k km it is still going strong as on day 1 as far as I can tell. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #398815 14th Feb 2015 8:13pm
dozerman
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
I always buy Halfords 5 year guarantee batteries (they were Bosch, now Yuasa I think). They are cheap enough if you have a trade card, and not too expensive at full retail. Halfords replace them without quibble within the guarantee period. I don't think the batteries are actually any better or worse than anything else but that no-argument replacement for 5 years is worth a fortune IME!
Post #398828 14th Feb 2015 8:35pm
jst
Numax get my vote, around £75 for 1000MCA, 110ish AH. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #398839 14th Feb 2015 9:17pm
