Home > In Car Electronics > Advice - Alpine 133BT Interference...
Venomator
Long story short... Whistle
My bog standard fitted Alpine 133BT unit...
... has been driving me absolutely bonkers on FM, with awful white noise type interference, sometimes blocking out reception almost completely on my London commutes! Big Cry
And yet around here (home area) I hardly notice the noise at all... Shocked
So, y'all know I have been whimpering about having to put up with a Heritage 90 HT, which has no AirCon... Evil or Very Mad
This morning I decided, at 0445hrs on my way down to Londinium, to try living without AirCon from now on! ... Laughing
Et voila - AirCon switched off = White Noise interference gone! Go figure... Rolling with laughter
I mean, really, go figure, or at least can anyone give me a clue where to start/look to resolve said interference, pretty please... Bow down
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #397756 10th Feb 2015 9:49pm
Venomator
Does this mean I have everyone as stumped as me... Whistle  Rog... Mr. Green
The GREEN One...
Post #397923 11th Feb 2015 5:56pm
need4speed
Im afraid i cant help with your problem, but i will be watching with interest as ive just taken delivery of the 133's replacement (173)..
Post #398153 12th Feb 2015 4:03pm
steve E
Wales
Hey Rog
I've turned the A/C and the stereo off Rolling with laughter
Post #398154 12th Feb 2015 4:07pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
It might be worth checking the aerial is fully fiitted into the rear of the radio. A poor earth will amplify any dodgy signal. I guess you could check the earth on the aerial itself too.
Simon
Post #398155 12th Feb 2015 4:07pm
Venomator
steve E wrote:
Hey Rog
A step too far for me Steve... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #398156 12th Feb 2015 4:15pm
Venomator
Simon
Thank you Simon... Bow down
I will give that a go at the weekend... Thumbs Up
Although it might be fun getting to the rear of the radio... Rolling Eyes
 Rog... Mr. Green
The GREEN One...
Post #398157 12th Feb 2015 4:17pm
couplands
I have the same radio (but in a TD5) and I bought a couple of levers that allow you to take the radio out of its DIN cradle in the dash. The levers were a couple of �.
Something like these.. http://www.ebay.co.uk/itm/Pair-Car-Radio-V...3aa2799fd0
cheers
simon
Post #398162 12th Feb 2015 4:42pm
Venomator
Again, thank you Simon, most helpful... Thumbs Up
 Rog... Mr. Green
The GREEN One...
Post #398246 12th Feb 2015 8:29pm
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
I have the same unit
And no interferance here. I have Defender Puma 2011 model. http://www.defender2.net/gallery/index.php?cat=13451
Post #399375 16th Feb 2015 6:10pm
Venomator
Thanks @aage, at least I know it means the fault is with my unit then... Thumbs Up  Rog... Mr. Green
The GREEN One...
Post #399381 16th Feb 2015 6:34pm
K9F
Hi Roger,
We use 12 volt PA systems linked with automotive audio and visual on our vessels. A product we have used are Ground Loop Isolators that will rid you of interference if you cannot find the source itself. You need to check all your connections for security and as far as possible all your cables (especially any screened ones) for chafing or cuts, together with the grounding of your head unit. I would specifically check any air conditioning earths as well, if they are compromised it may be seeking an alternative route that may affect your stereo perhaps? One of these being a cheap investment may help. These are exactly the ones we use.....
Hope this helps....
http://www.ebay.co.uk/itm/Ground-Loop-Isol...118wt_1197 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399383 16th Feb 2015 6:38pm
Venomator
Thank you Mal... Bow down
Watching that one, as it isn't BIN but, jic, are any of the others listed as good, there is only the one of that specific listed... Whistle
I didn't get around to it this last weekend, but plan to check it out next and will get one in any event... Thumbs Up
 Rog... Mr. Green
The GREEN One...
Post #399413 16th Feb 2015 7:49pm
K9F
Evening Roger,
As you can identify that the issue happens when the air conditioning is on you can perhaps negate the requirement of a ground loop isolator by ensuring your head unit and air conditioning is grounded/earthed at exactly the same point. This will ensure no potential difference between the two. Even if you have the time and inclination to slave in a temporary cable to test this suggestion out it will give you a pointer perhaps?
In my work scenario the issue causing the interference can be two decks below and the GLI is simply a 'workaround.'
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399426 16th Feb 2015 8:11pm
Venomator
Gotcha Mal, thanks again, I guess I'll find out when I pull the thing out and check it... Mr. Green  Rog... Mr. Green
The GREEN One...
Post #399428 16th Feb 2015 8:17pm
