Home > Maintenance & Modifications > PAS
PAS
Does the steering box leak / is it prone to leaking on Puma's?
Mine seems a little weepy but not dripping nor is there a problem.
Seems to be just above the steering damper nearer theslightly nearer the NS.
Post #396779 7th Feb 2015 9:17pm
I've not heard of many problems with the puma box, certainly fewer than earlier ones, which is interesting since they are all essentially the same. The most common place to leak is round the output shaft past the bottom seal, and the PAS fluid can then run along the drop arm and get to the damper area. It might be worth having a thorough clean to try to see where it's coming from.
It's not difficult to change the box but access is not good.
If it's not dripping and the level isn't droppjng (assuming of course it is the box leaking), I wouldn't worry.
Post #396808 7th Feb 2015 10:23pm
Yes, it is tracking down the drop arm indeed.
The fluid level certainly doesn't seem to drop more is it actually dripping, just enough that there is oil marks present and to cause dampness there.
I agree, I'm not worried really just wondered if there was likely to be anything come of it or not.
I tend to just give it a clean of occasionally, usually only once or twice a year. Laughing
Post #396836 7th Feb 2015 11:13pm
