Home > Puma (Tdci) > washer nozzle
benn01
Brazil
washer nozzle
I just noticed mine is smashed...is this a big a hassle to repair as in the td5? Thanks
Post #395031 2nd Feb 2015 2:06am
x-isle
Depends which part is broken.
If it looks a bit like this;
Then all you need to do is purchase a new complete one, pull the missing bit off and glue it back on.
If you need to change the whole washer, then it's much more difficult than before, as you have to remove the Puma dash.
Alternative washer jets have been mentioned a few times over the last few weeks. I'm waiting for bits to arrive to convert mine. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #395131 2nd Feb 2015 2:32pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If it's like one above, it's often due to the cold weather. The water in the nozzle freezes, expands and either cracks the push-fit part or just pushes it off (or both).
Simon
Post #395159 2nd Feb 2015 4:47pm
benn01
Brazil
Thanks, going to inspect it tonight. Hoping I don't need to take the dash apart like last time!!
Post #395293 2nd Feb 2015 10:22pm
Lou Sparts
Have never replaced one but have often wondered if it can be done through the hole that the ash tray sits in (pre Puma). 2005 Td5 90 XS
Steve
Post #395298 2nd Feb 2015 10:26pm
benn01
Brazil
I did see the alternative options, this is the third time I lost mine, the other two times they were confirmed crushed and not just separated. It was too dark to inspect it and I really didn't know this was an option.
I will check it out tonight.
Post #395299 2nd Feb 2015 10:27pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
If it's the black plastic jet like the pic then you don't have to remove the whole dash. My Indy removed the dash fascia and got at the washer hose and locknut that way. I was expecting a dash out job too!
Post #395302 2nd Feb 2015 10:29pm
benn01
Brazil
with the entire dash out pre-puma it was still a pain
Post #395303 2nd Feb 2015 10:29pm
RED-DOT
I thought this could be done by removing the centre console with the radio etc but there are two metal air vents in the way so i reckon it's the whole dash out and you all know what a big job that is. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #395360 3rd Feb 2015 6:43am
schuee
Driving to work this morning and pressed the wash wipe, washer jet flew off Big Cry anyway just had a look and mine is exactly the same as in your picture x-isle, will get one ordered today and get the glue out.
Post #395393 3rd Feb 2015 10:36am
x-isle
...or if you are interested, hold on a few days and I'll post my Peugeot 405 wiper upgrade........ If it all goes to plan. Craig Rogers
2007 Puma 110 XS
Post #395395 3rd Feb 2015 10:39am
I haven't attempted this myself (though I have now had the Puma dash out several times) but I would have thought that you could get at the inside of the washer jet on a Puma without actually removing the dash if you free the dash off completely and pull it away from the bulkhead. You can change the wiper wheelboxes using this approach, so the jet could probably also be done.
It is still not a job for the faint-hearted, but it only takes a few minutes to free off the dash.
Post #395397 3rd Feb 2015 10:48am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I've done this mod on my 300, granted it's much easier to remove the dash on that than on a puma, it only took half an hour and job done, the difference is amazing and so much better, who'd have thought that such a simple mod would make driving on a wet motorway so much easier. You get the water exactly where you need it, in the path of the blades.
In regards to the puma, Wonder if it would be worth bypassing the pipes before they go into the bulkhead and perhaps reroute them to pass behind the bonnet and straight to the wiper blades?
Post #395401 3rd Feb 2015 11:00am
x-isle
Thumbs Up
I did think about rerouting, but quite like the fact that the pipes go behind the dash as the heat from the windscreen heater duct can help defrost the pipes a little quicker. However, saying that, the amount of exposed pipe outside will still freeze up. I'm guessing this is maybe why Peugeot stopped this design after the 405 and 605. Craig Rogers
2007 Puma 110 XS
Post #395419 3rd Feb 2015 12:30pm
I wonder if is it feasble to remove the heater coil from an off-the-shelf heated nozzle (eg the RR type) and fit it into a standard LR Defender nozzle. There's certainly room in the nozzle moulding for a coil.
What I really want is a heated Defender nozzle, because if anything's going to freeze it will be the nozzle first.
For a warm/hot screenwash, I can't see any reason why something like a TD5 fuel cooler couldn't be used as a washer fluid heater - connect the cooling hoses as normal and run the washer fluid through the fuel passage. It is a simple heat exchanger, after all.
Post #395450 3rd Feb 2015 2:23pm
