Home > Td5 > Oil in the Wiring Loom
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Hey team!
So - i've got rather a lot of oil in my 2004 TD5 110's ECU compartment, as yet no mis firing but I am thinking it would be better to fix this now rather than wait for a problem!
Have done some reading and I reckon even for someone with my limited ability it's easy enough to do based on my not replacing the main wiring loom but just the injector harness. My questions if I may are as follows (sorry some of these are really basic/foolish):
1) What is the difference between the Paddocks Wiring Loom http://www.paddockspares.com/amr6103-injec...l?___SID=U and the Devon 4x4 One http://www.devon4x4.com/index.php?page=sho...;Itemid=14? The Devon one is £48 versus Paddocks £28, any thoughts on which to get?
2) I gather you need to seal the new Injector loom otherwise the same will simple happen again, people talk about an oil resistant sealant - what is good for this? Sorry it's a thick question but want to use the right one! Do you literally just coat the connector end with this?
3) My third foolish query is this - what solvent cleaner should i use on the main loom to help clear the oil out? Don't want to use the wrong one
4) If i put a new gasket on the rocker cover, do i need any past on it or anything like that?
5) What torque should the bolts on the rocker cover be done to?
Thank very much team - really appreciate assistance!
Anthony
Post #394869 1st Feb 2015 6:26pm
K9F
Q3....Any electrical cleaner as any residue will evaporate......I would probably go with the Electrolube one! Thumbs Up
http://www.amazon.co.uk/s/?ie=UTF8&key...httirrru_b If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394874 1st Feb 2015 6:38pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Very good guide here...
http://www.discovery2.co.uk/Injector_harness.html
It's for a D2 but the same applies. The guy's guides are really very good.
Think it answers more or less all your questions. Other than the one about the D4x4 one vs Paddocks...
Tbh no idea. D4x4 are not quoting a part number but both are listed as OEM so I'd probably just get the paddocks one.
Post #394875 1st Feb 2015 6:43pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #394898 1st Feb 2015 7:51pm
Northernremedy
Hey thanks!
Great guide and cheers for explaining the cleaner stuff.
Oh dear god. Which to choose?!!!!
Post #394907 1st Feb 2015 8:07pm
Freypal
Given the relatively low cost I'd go for the Genuine part and avoid the Britpart item for starters.
Post #394921 1st Feb 2015 8:39pm
Northernremedy
Just to say thanks for all the advise Bow down
So I did it this afternoon, took me under two hours. Refitted with genuine loom and gasket in the end, decided not worth saving pennies on that. After it was all refitted she fired up like a good un! Put silicon grease in the plug on the injector loom and also round the blue seals so hopefully this will discourage further migration. Now I'll just drain it at the ecu end every few days.
Thanks again!
Post #397037 8th Feb 2015 7:02pm
K9F
Good result. Thanks for getting back. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #397040 8th Feb 2015 7:04pm
Freypal
Glad it went well. Hopefully now cured!
Post #397059 8th Feb 2015 7:45pm
