![]() | Home > Tdi > R380 Gearbox Advice Please |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
If your going to do it , do it once upgrade parts AShcroft all day
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Yep, happy to upgrade to suffix L as I believe it has a stronger main shaft? Not sure i need the rear HD support bearing or the 5th gear ratio upgrade. As I say it's not tuned in any way and I don't tow, happy to consider it though.
The question would be, do I need the suffix L box and the HD support bearing....not sure? Don't have any knowledge of this stuff? ![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Speak to Dave at Ashcroft
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
Hi,
PM me your number, will call you tomorrow to discuss, Dave Ashcroft Dave |
Thanks Dave, will do.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6020 ![]() ![]() ![]() |
I think my g/box failure was caused by the 5th gear bearing, so when I did mine, I opted for the bearing upgrade. 1999 Defender TD5 110
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225 ![]() ![]() ![]() |
Hi, what did you decide to go for? I need to make a decision on mine.
Having spoken to Dave today I'll be going for like for like gearbox Suffix J and input gear/bearings. No requirement for upgraded HD bearing based on what I use it for.
Starting the strip out this weekend. Issue with 5th gear but new one should be good for 80/90k miles so good for me. ![]() Thanks also to Dave for your advice. ![]() ![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
I would hope it will last more than that! 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
5th gear bearing Dave not the gearbox itself. Not sure when mine actually failed but the Defender had 102k on it when I bought it so sounds about right.
Only time will tell but I'm only covering upto 3k a year on mine so should last a while. 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
