Home > Td5 > TD5 Central Locking
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
TD5 Central Locking
Hi, I was wondering, is it feasible to fit central locking to 110 TD5 2000 MY Van. Is the wiring loom standard or would I need a later loom, i know i would need actuators and the relevant AS 10 module, is there anything else needed and what's the best way of obtaining the parts.
all evidence appreciated Bow down Bow down
Post #393007 27th Jan 2015 3:54pm
mk1collector
It will be easiest and cheapest to buy one of the cheap kits off ebay. I think hawk are the usual make. Finding all the genuine parts will probably cost a small fortune.
Post #393013 27th Jan 2015 4:11pm
Romadog
It can be done.
Correct 10AS unit (Expensive new, so search ebay, breaker etc)
Loom between B posts for rear doors. A b Censored ch to extract so purchase new.
Bulkhead loom ( extract the wiring inc. switch plugs etc concerning CDL )
Actuators x4 )
Door looms) These last two are best found from a breaker.
By doing the above its just plug and play and easier to check if there are any issues in the future.
Remember its been tested by Land Rover in many vehicles.
Do electric windows at the same time... Thumbs Up
Post #393055 27th Jan 2015 7:27pm
PaulMc
A non-central locking 10AS can easily be modified to operate central locking.
Either, by soldering the correct NEC relay to the circuit board, or by soldering wires to the pads that would trigger the NEC relay, and running them to external relays.
The wiring from the 10AS to the front doors can easily be added as an overlay harness, as can the wiring to the 2nd row and tail doors, if required.
The wiring for electric windows can also be added as an overlay harness - either, separately, or as part of a combined central locking/electric windows harness.
Door harnesses can be difficult to find from breakers - they used to be fairly reasonably priced to buy new.
. Paul.
Post #393077 27th Jan 2015 8:21pm
tazmarkuk
Thanks for the info guys, some home work in hand me thinks
Post #393420 28th Jan 2015 9:13pm
Romadog
Nip down to Equicar and speak to Simon
www.equicar4x4.co.uk
Post #393741 29th Jan 2015 7:17pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Any 10as will be able to do central lock and alarm. You need the Nec ep23n1s relay.
Open the green box up n solder it onto the pcb n you are looking at pin 2 and 3 for the lock unlock drive.
Oh you'll need a nano com or similar to set the parameters. The defender has migrated, leaving the owner behind.
Post #394407 31st Jan 2015 2:47pm
