Home > Puma (Tdci) > Those with winches
mse
Those with winches
When you fitted your winches to the front did you need to upgrade the front suspension?
On previous 90's i have, but none had the "heavy duty" suspension that you get anyway with a CSW. Mike
Post #2264 1st Jun 2008 9:28am
Verdone
Belgium 2007 Defender 90 Puma 2.4 HT Java Black
no, have an equipe winchbumper with winch and still on standard suspension Cool
Post #2266 1st Jun 2008 10:04am
mse
Great - makes my life easier Thumbs Up
Just to order another winch bumper not to get the brand new warn winch out of the box at 6 months old! Mike
Post #2267 1st Jun 2008 10:40am
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
i thought i'd keep my standard set up but after a few months decided to up-grade, IMO it's worth doing it , truck looks better and sits better on the road. it's only £180 for a pair of OME's....
Post #2275 1st Jun 2008 2:32pm
TJ101
On the 07, have the Factory winch and front bumper fitted,, and at present the standard front springs,,which even with 255/85 MT. have been OK,,, but truthfully, they are in need of changing to something a tad stiffer !! another job on the list sometime California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2279 1st Jun 2008 6:26pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
I upgraded to OME and it is alot better than before, I found that with the winch and standard springs it got a little bit wayward at the rear end! 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #2281 1st Jun 2008 9:43pm
mse
So its a bit of a split at the minute, between the old rule i had of they need to change and they will be fine.
What im trying to work out is the usual heavy duty front springs are 90 rears - although the CSW is supposed to have the Heavy Duty all round from the factory - so what springs have you guys been using on the front?
With the roof tent on the back is down a little anyway so dropping the front isnt a huge issue i cant say i want it too feebal on the front. But im not a fan of just chucking any old springs on; i know from past experience (and advise) that genuine LR springs are better (after all the spend £billions of R&D)! Mike
Post #2285 1st Jun 2008 11:45pm
Alex e
best thing to do is phone a 4x4 supplier with your requirements and they'll sort you out with the right set up.
mine are OME 761's (i think)
Post #2288 2nd Jun 2008 8:05am
mse
Sorry Embarassed i really disagree. Most of the suppliers dont know what they are talking about and source the springs from the same place. Some are worse than others - the best ones are the LR genuine springs. Mike
Post #2289 2nd Jun 2008 6:17pm
Laurie
Try Famous Four - they know all about springs and shockers
Post #2290 2nd Jun 2008 8:36pm
Alex e
found a link to a site which explains a lot https://www.expeditionexchange.com/ome/indexsprings.htm
after checking the box mine are 751's
Post #2291 2nd Jun 2008 9:34pm
mse
That site is a good site - been around a few years; they used to have a huge resource before a website change seemed to loose a lot.
Interesting read though.
The thing with springs is Land Rover do spend some serious cash on this; ive never seen aftermarket suppliers spend this much - thus you always seem to get a change; land rover is taller, decreased travel (articulation) etc
This is why ive built up a great deal of reluctance on none OE springs. Mike
Post #2293 3rd Jun 2008 8:14am
AndrewS
Mine and SWMBO's both have OME 2" lift springs front and rear. Luvley smoother ride Thumbs Up
Post #2315 5th Jun 2008 7:19pm
