![]() | Home > Wheels & Tyres > 7.5 16 height compared to 235.85.16 tyres |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041
Its not a MT but a BFG AT with 3500 miles of wear and I am 180mm. HTH. (235/85 R16) 1999 Defender TD5 110
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
A 7.5 R16 has a diameter of 31"
A 235/85/16 has a diameter of 31.7" 0.7' will give an extra 0.35" or about 9mm difference in height of vehicle. Bit of handwaving, depends on depth of tread/tyre pressure etc but gives you a rough idea. Brendan |
| rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150
Thanks guys, It should fit in the garage with 10mm to spare.
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
After responses to a previous request to measure vehicle heights - it was apparent that no two Defenders (even with the same wheels/tyres) were the same height.
Springs are another variable in your equation - so allow for a degree of tolerance in your research. Whether 10mm is enough I wouldn't like to bet on? Waste of time dealing with published sizes - tyres are not circular when inflated and carrying the weight of a vehicle. I've got a set of new Good Year Wrangler MTRs (less than 1000 miles) on my 2014 90 Station Wagon and just 5 minutes ago I checked the overall vehicle height - a couple of mm short of 2000mm. Distance from edge of rim to edge of tread around 170mm - but at the bottom where the tyre is fully loaded that drops to 160mm. Of course the distance from edge of the rim to a line from the centre of the tread at its highest point is far greater. |
