![]() | Home > eBay & Bargain Spots > Td5 nanocom on eBay uk for £39.00 |
Nanocom Classic for td5 on eBay £39.00
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Software only,
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Ive seen this in the past, looks like he is a map file leach.
I wonder whos files he is ripping off ? Pete |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
That's not good .....
This is the problem with Ebay sellers
![]() Last edited by bell-auto-services on 18th Jan 2015 7:08pm. Edited 1 time in total |
Id suspect its been ripped off from a car that was done either with a different tool originally or a car that was done before the nanocom could read out.
Pete |
There is a Nanocom one now at ebay still cheap.
http://www.ebay.co.uk/itm/Land-Rover-TD5-N...2edd8c0159 I was following it but he doesn't want to ship outside the UK and I found a newer version already. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
On the basis he used to list them as 'Twisted' ... I would assume it's whoever does the Twisted maps ... assuming that's where it's ripped from.
There's plenty of open source software about and map files floating about for the TD5's. I looked into this for many many weeks and basically had enough software to write a complete ECU and the hardware, if bought from China, can be very cheap to (and reasonably reliable ... able to tune many other ECU's to). I still however went to the pros (BAS in my case) as at least then, if something goes wrong, you can poke someone on the shoulder and get assistance! Plus it's supporting them, to keep them going. If they weren't around, the maps wouldn't be around to get ripped! I used to download software in my youth without thinking about it, but nowadays, you just realise what sort of hit it can have. |
