![]() | Home > eBay & Bargain Spots > Halfords sale, jack + stands |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 ![]() ![]() |
Would this be sturdy enough and lift a defender high enough?
I cannot get the link to work here but the item is in Halfords sale underer motoring, see discription bellow. www.halfords.com/motoring/garage-equipment...ifting-kit Halfords 5 Piece Lifting Kit The Halfords 5 Piece Lifting Kit has everything you need for car maintenance! The set includes plenty of useful stuff to ensure any lifting you need to do is a piece of cake. Halfords 5 Piece Lifting Kit Extra Info 2 Tonne Trolley Jack with Short Wheel Base has a lifting range of 14cm to 34cm. Made with a durable welded construction 2 x 2 Tonne Axle Stands have a combined weight capacity of 2 Tonne Padded Car Creeper allows for comfort whilst carrying out under car maintenance Wheel Wrench with 17/19mm socket allows for a wheel change 2 x Wheel Chocks allow the vehicle to secured in place Additional Information REMEMBER: It is essential to use axle stands when working under a vehicle. Jacks are not designed to hold a vehicle for a prolonged period of time.[/img] 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
For the price and obviously depending on frequency of use, surely this is a great buy for occasional use...
![]() Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
I think you might struggle with the size of jack
lifting pad too small lifting height not enough I think your regret buying the smaller jack I would go Halfords advanced jack 3t ( black one ) and advanced axle stands ( black ones ) , but are more money I know |
Okay, thanks for the experienced input on this Munch...
![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Okay thanks for that, so another way would be
4 Tonne Bottle Jack with the Advanced 3 Tonne Ratchet Axle Stands Does this sound a better alternative? 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
bottle jacks are not the most stable of things , would not be my choice of jack
unstable and lifting pad area even smaller advanced trolley jack really |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
I use a 4 tonne bottle jack and I have two 3 tonne ratchet axle stands. Simply pump up the axle and slide the axle stand under nice and easy
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
This link
http://www.halfords.com/motoring/garage-eq...ifting-kit 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
You can get 3 tonne ratchet stands for £15 from Costco or online,I use a 10 ton + bottle jack but as said they're not very stable.You can get a good 3 ton trolley jack for around the £80 mark.
These seem to be generic jacks sold from various dealers,ignore the "sale" price,they're £80 wherever you go,lol. http://www.sgs-engineering.com/tj3-garage-...ore=sgs_en o/t,anybody else unable to click on the Halfords links?? Pov.spec,ftw. 2006, 110,TD5. |
Odd, as the link I pasted was direct from Halfords.
Machine Mart are doing a VAT free day according to the email I got 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
Trying to work out why we are mangling the links.
It seems to be a Trade Doubler issue Martin - if you remove all their prefix stuff in the url it works fine...
When are they doing a VAT free day, I looked on the website and there was nothing mentioned, maybe you have a speacial code? 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
yes you normally have to be on there email list then print off a coupon
