![]() | Home > Puma (Tdci) > 2.2 Clattering on cold start - any ideas? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
I had big end noise, that was eventually worked out to be a new vcv, my noise was when hot, but then fitted new vcv and got noise (less) when cold until it was re calibrated into the fuel system
So my guess is either new vcv required and re calibrating, or just re calibrating your existing one. BUT mine was on a 2.4 Tdci, so may be completely wrong. Andy |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Thanks Andy but what's a vcv?! 2003 Td5 110 Hardtop
Now a 2013 110 USW too. |
Variable control valve. It's a small electronic thing that bolts to top of the fuel pump. Easy to change but very very fiddly. But then computer kit needed for programming.
Andy |
Aha!
Thanks, I'll suggest it to the dealer. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Bit of info here
http://www.defender2.net/forum/topic29678-15.html |
That's great thank you. 2003 Td5 110 Hardtop
Update - well the dealer's not interested.
'Its a normal sound for a Defender. Sir.' Bloody well isnt. Does it get worse if a variable control valve problem? And if it is VCV, what's actually happening? 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
I can only say by my experience, but I think it's overfueling causing diesel knock which is not good, as it can't control the amount of fuel correctly. I don't know if it will get worse as that will depend on if your VCV (if it is that) just needs re calibrating into the system, or if it is failing. If failing I think it will get worse, to a point that the knocking is considerable, and more constant.
A recalibration for someone who knows what they are doing, and has the kit is a very very very simple job, less than an half an hour, and would certainly assist with assessing the noise, and be my first stage. Andy |
