Home > Td5 > Rear side/ stop light problem
orled
No problem with side light but nearside brake light was intermittent. Changed 21/5w bulb but still no brake light. All other lights ok. Next step?
Post #385380 6th Jan 2015 8:17am
mk1collector
Brake light switch or try unplugging the tow electrics and see if it makes a difference.
Post #385423 6th Jan 2015 12:14pm
K9F
Multimeter and check both the supply and earth. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #385437 6th Jan 2015 12:53pm
