Home > For Sale & Wanted > [SOLD] Light Brackets for Through Grill Mounting |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 |
Following this thread: http://www.defender2.net/forum/topic26950....+bar+grill
on fitting some front lights supported on brackets through the grill, I then found these brackets, rather than make up my own. They are supposed to fit to the grill mounting bolts at the sides of the grill to give light mounting points through the grill. They were originally described as LED warning light mounting brackets. Click image to enlarge Plans have changed now, so these are surplus to requirements. Looking for �35.00 posted. Last edited by Inigo on 11th May 2018 10:40pm. Edited 1 time in total |
5th Jan 2015 4:55pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Cannot see how these fit any pics of them fitted might be interested.
5th Jan 2015 6:21pm |
Thought I could mount led bar on these rather than a-bar but really need to see how they fit.
5th Jan 2015 6:34pm |
Here they are fitted no good for me though
5th Jan 2015 6:42pm |
They came with no instructions and I had to hold them against the front of the car with the grill removed for a while before I worked it out, but didn't take photos!
The cross at the top of the T (in the orientation shown in the photos) has two mounting holes, these match up with the bolt holes (currently with plastic inserts) for screwing the grill back on. These would need to be replaced with nuts and bolts, or perhaps it might be strong enough just fitted between the grill and the steel panel behind it with the existing screws? This then leaves the long vertical part of the T (in my picture) poking sideways across the grill. The two large holes and two small holes on this part, I assume fit to a fairly standard LED strobe light. I was going to drill in the appropriate place and add bolts to poke through the grill to fit an LED light bar. I was going to try and do something like LeeNorthant's picture here: https://s3-eu-west-2.amazonaws.com/i.hubnu...7ad038.jpg Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
5th Jan 2015 6:49pm |
Ah, thanks SGH, as ever, a picture paints a thousand words.
5th Jan 2015 6:50pm |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
The way I say them was through the gap between the Grill and the wing sticking straight out. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
5th Jan 2015 6:55pm |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 |
I think I'm right in saying that those are made by Border Motorsport - give Robbie a shout if you've any queries, he's a really helpful bloke.
Ross The Scotia Winch Challenge |
5th Jan 2015 7:53pm |
