Home > Puma (Tdci) > carpet and dynamat
Ollie Wall
England 2007 Defender 110 Puma 2.4 DCPU Alpine White
carpet and dynamat
Was wondering if anyone has dynamatted and fitted the exmoor trim full carpet set, this is for a base spec no soundproofing double cab, just fed up of having to shout on the motorway!
is it worth it?
thanks
Ollie
Post #384293 2nd Jan 2015 9:23pm
JAY BOY
Wales
Post #384298 2nd Jan 2015 9:33pm
landy andy
Dynamat and Wright off road acoustic rubber mats in mine. Chucked the carpets away.
Post #384339 2nd Jan 2015 11:18pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Short answer is, yes.
I Dynamatted my USW and fitted Exmoor carpets to the load area and rear seat area. Also egg crate foam on the loadspace side walls.
No need to shout on the motorway now.
Also, tyres seem to make a huge difference. I went from Conti cross contact to Grabber All Terrain 2s, and the difference was night and day. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #384354 2nd Jan 2015 11:57pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I was thinking of posting a similar question after reading November LRO International and read about 'halving the noise levels' in a Defender with an Exmoor trim moulded mat. Seems a bit optimistic, my Td5 h/t is fairly noisy even though i've used some Noise Killer sound deadening in the cab. Surely the std matting can't be that bad?
How much better is it after a few 100 £'s worth of Dynamat or Exmoor acoustic matting?
Post #384379 3rd Jan 2015 12:55am
landy andy
I noise killered my Td5 90 and had standard rubber mats, but the acoustic mat is much better. The exmoor trim mat is the same as the Wright off road one, exmoor buy in from Drew Wright, so I would buy direct. Once you lift up your parcel you'll understand why it works Whistle
Andy
Post #384380 3rd Jan 2015 1:03am
JAY BOY
Wales
I have only done the back in mine. I've got to do the roof lining when i have time but the difference is very noticeable.
driving on the motorway or faster A roads its a reasonably quiet car, You can have a conversation without shouting and you won't need the volume to the max on the radio when your on your own.
Highly recommend it. Thumbs Up Thumbs Up
Post #384381 3rd Jan 2015 1:04am
