Home > Puma (Tdci) > Paint Flaking off Underneath Arch Extension!?
Xelr8
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Is it normal for the Paint to Flake off in big pieces underneath the Plastic Arch Extensions Question
I only washed it with a Hose on low pressure?
My worry is that it will all come off the underneath & then start to peel over the lip to the Exterior part of the Arch Extension Question
And I'll then end up with Black Arch Extensions Big Cry
Post #383068 29th Dec 2014 5:45pm
K9F
Usual...."They all do that Sir!" Laughing Thumbs Up
http://www.defender2.net/forum/topic3114.h...ing+arches If you go through life with your head in the sand....all people will see is an ar5e!!
Post #383069 29th Dec 2014 5:47pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Rolling with laughter yes this happens along with various other niggles that we have to put up with I wouldn't worry about it although it is quite annoying
Post #383072 29th Dec 2014 5:50pm
Xelr8
Oh Ok
That makes me feel a bit better Laughing
I suppose you could have just said.........
Welcome to Defender Ownership Rolling with laughter
Post #383073 29th Dec 2014 5:52pm
Yes it happens, will never creep to visible areas though.
Post #383074 29th Dec 2014 5:52pm
Xelr8
Thanks for the replies guys Thumbs Up
Post #383076 29th Dec 2014 5:53pm
K9F
Is 'visibe' french? Happy New Year nearly Steve......‎bonne année! Laughing Bow down
Welcome to Defender ownership, have you checked your gulleys for any other parts that may have dropped off apart from paint flakes?
Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #383079 29th Dec 2014 5:55pm
Mal - Bloody iPad, it got it wrong first time but I thought I corrected it obviously I did afterwards too. Rolling Eyes
Thumbs Up
Post #383085 29th Dec 2014 6:07pm
Pickles
Yes, I was told (by this forum!) that it's totally normal. Happened to ours (still is), & I too was worried that it would spread to visible areas.
Pickles.
Post #383178 29th Dec 2014 10:01pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
And to confirm mine is also peeling Rolling Eyes
concerned at first but as advised it is only within the arch and has not spread further
Post #383184 29th Dec 2014 10:11pm
I'd hazard a guess that the insides are not primed at paint, but given a quick base coat spray over.
Could also be overspray too.
Post #383206 29th Dec 2014 11:00pm
CatherineF
What if Dinitrol stone chip stuff is sprayed up into the arches?
Post #383208 29th Dec 2014 11:02pm
You can do that, that's what I did before applying Dinitrol.
But I made sure it was absolutely perfectly clean and as dry as you could possibly get it in mid summer first.
It does indeed calm down any flying stones in the tyre tread.
Post #383210 29th Dec 2014 11:05pm
munch90
its just overspray flaking off the plastic
Post #383211 29th Dec 2014 11:06pm
TJ101
Yep
When i did the underside of the new one, also Dinitroled the inside of the wheelbrows,
As said, they all do that, even with a hosepipe ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #383212 29th Dec 2014 11:06pm
