Home > Tdi > Rear demist electrical conundrum 300tdi
g-mack
Ok so getting a bit steamed up tonight I switched on the rear demist. When I got home and removed keys the dash warning light remained lit! I left it 10 mins and no change. Strangely when I clicked side lights on my drls lit too! They only come on when they sense voltage over curtain figure. Disconnected battery for now. Any clues why it would do this? My 109 thread
my youtube channel
Post #382419 27th Dec 2014 8:09pm
dorsetsmith
cct for 300tdi Rear demist electrical
Post #382445 27th Dec 2014 9:08pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
I had this on my 90, took the switch part and gave it a good clean up. Worked after that.
Post #387485 11th Jan 2015 6:13pm
Lacy
Yep, I would say either a dirty switch or sticking relay.
Post #387554 11th Jan 2015 9:38pm
g-mack
I've sorted it! There wasn't actually a problem lol. I rarely use it and hadn't realised how it worked. If I switch it on I have to switch it off! Now I can only switch it off if the key is in pos 2. I presumed it would switch off itself with key removed. so as long as key is turned it switches off no probs Thumbs Up My 109 thread
my youtube channel
Post #387568 11th Jan 2015 10:11pm
Cupboard
so if you forget to switch it off when you turn the ignition off it drains your battery?
I can't think why they did it non-ignition switched, and even it it was live all the time I can't think why you wouldn't be able to turn it off with the ignition off. It's like you've got an ignition-live switch controlling a permanent live latching relay.
Post #387580 11th Jan 2015 11:09pm
g-mack
its a 300tdi with a td5 dash,so im guessing whoever did the conversion has wired it incorrectly! another thing for the to do list i guess Very Happy My 109 thread
my youtube channel
Post #387584 11th Jan 2015 11:26pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Is there any advantage in having a TD5 dash? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #387621 12th Jan 2015 8:12am
steventheplumber
Looks very smart
Post #387622 12th Jan 2015 8:21am
g-mack
mine had replacement bulkhead, and it came from a 2005 td5, dash was included so was fitted Thumbs Up i think the td5 dash gives you a better center consul. the biggest improvement is by reteo fitting the dials (which im about to do) as they are much brighter/clearer lit and way more up to date looking. Thumbs Up My 109 thread
my youtube channel
Post #387637 12th Jan 2015 9:48am
Dave T
may just have to look into that then...... 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #387678 12th Jan 2015 1:34pm
