Home > Maintenance & Modifications > Automatic oil cooler
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Does anyone know if an automatic gearbox oil cooler needs to be force air fed, like the intercooler and rad.
or can it just be installed anywhere on a vehicle ?
Thanks
Peter
Post #381741 25th Dec 2014 10:18am
Some fit coolers (like on challenge trucks) in the tub behind the bulkhead, but as with any cooler, it needs air to remove the heat, so in an air flow would be preferable.
The ones i've seen fitted in the back of vehicles usually have a fan on them too.
Post #381750 25th Dec 2014 10:41am
Alex1976
From what I understand there is no such thing as overcooling an auto box - so the more air flow/cooling the better.
I have a standard discovery oil cooler on my Defender and I am considering uprating this to a heavy duty Allisport one as I think my auto box gets too hot when I am pushing it hard.
I have my auto cooler mounted up front (in front of the rad and intercooler) so it gets as much cooling as possible.
Post #381788 25th Dec 2014 12:33pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
I used to replace the oil cooler with a made up hydraulic hose, the longer the better to dissipate more heat.
You can either run it up and down the chassis or in a snake behind the front grille.
This was on comp safari motors where the autobox got beaten to death. The advantages being it doesnt get bothered/clogged with mud and you can run it anywhere. The longer it takes the oil to get back to the autobox the cooler it becomes and you are also increasing the volume of oil which prolongs its life. Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #381909 26th Dec 2014 12:47am
or you could fit one of these nearly anywhere:
Post #382251 27th Dec 2014 11:15am
K9F
That's the same principle used on the vessels I work on where each engine has a ton of oil in them. Where are you going to get your supply of cold water from to cool the oil sufficiently on a vehicle? Easy on a boat you have an endless supply upon which you are floating. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #382256 27th Dec 2014 11:28am
rallysteve
Quite a few vehicles have water to oil coolers which can also help to bring the oil upto temperature. Although a damaged cooler on an autobox which could let water into the fluid would ruin the box. 02' 110 TD5 Double Cab Rebuild Thread
Post #382270 27th Dec 2014 12:29pm
Many people rate these over a traditional air to oil cooler
http://www.laminova.se/products/oil-coolers/
especially in extreme applications.
Post #382280 27th Dec 2014 1:27pm
jst
I run a Laminova, the largest one on one of my trucks. It's ok but has its limitations. In the end I fitted ask inline air to oil cooler too. Disco one.
I also run a 19&23 route seen cooler air to oil on another truck but run dedicated fans.
these are all on hp24/22 amalgamated boxes from Ashcrofts.
I would run a dedicated fan if its a std cooler unless your on small 31" tyres, or not towing. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #382437 27th Dec 2014 8:44pm
