![]() | Home > Puma (Tdci) > Rear Heater Blower |
Not what your looking for, but I have seen a series 3 with a small household radiator fitted in the back and it was bl@@dy brilliant
Something like this
eBay Item No. 201220150656 |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Interesting Thanks.
Bit over my price range ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Yea bit pricey , but think it would suit , old and new look etc
Mini is a self contained unit , matrix and fan in one unit , might not look the best to be honest |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
look up Maradyne on google
http://cdn3.volusion.com/syzrq.xwfmv/v/vsp...012-2T.jpg DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
When I bought my 110 V8, it had an enormous cubby box fitted with what I think is a standard LR heater matrix nad fan t-eed in to the coolant circuit, in series with the LPG vaporiser. It's one of the best things about the vehicle, as far as the children are concerned. In the Defender, when it is cold, it takes an age for the rear footwell to warm up and when it is really cold it simply doesn't.
any pics? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
I've definitely seen an arrangement where the air from the 'down' (footwell) setting is diverted via two tubes to out the back of the centre cubby. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Have a look at what they sell here - http://stores.ebay.co.uk/theheaterstore
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thanks for the links
![]() Thats the sort of thing, but its working out where to put a unit. Under the rear seats?? Also running the pipe work to it should not be to bad. Just tap into the pipes in engine bay & route along chassis & up & in Anybody done an extra heater in a Puma yet?? Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
how would you plumb in the aux heater ?
tee into std heater pipes , possible air lock problems with coolant not being pushed in one length direction ? ( this way your adding onto primary cooling circuit , but not in a one pipe length circuit if that makes any sense ) or take feed to aux heater from outlet to std heater , then aux outlet to std heater return pipe to the engine , so really coolant is pumped round in one direction still ? (this way your adding to primary cooling circuit , but in one pipe length , ok I know your using water that's already been through std heater , but guess it would still be hot enough to use again ) not sure ? never done it myself |
Please see enclosed pics of my rear heater, installed by PO. He was a boat builder, so everything is made out of wood/mdf where possible. The cubby is enormous, but the heater does work remarkably well for heating the kids feet in winter.
It is in a V8, so no worries about removing too much heat from the engine - perhaps that might be an issue with modern diesels? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I've been following this thread with interest as thinking about the same for my 110 SW and heating for the passengers (ie kids) in the back.
I like the look of the sa12-5000-3 (http://www.ebay.co.uk/itm/SA12-5000-3-12-V...1199118786), but as this draws 50amps I was wondering if the alternator would be okay with extra draw on a cold morning just after starting? I was thinking about mounting under the second row of seats. Thoughts..... |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8331 ![]() ![]() ![]() |
alt will be fine, it depends on the battery and how long its going to run for before being turned off again and expecting restart. Cheers
