![]() | Home > Technical > Defender Puma 2.4 110 2007 Throttle overrun |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 ![]() ![]() ![]() |
Had a similar problem to this and it was the clutch switch. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
Check your brake lights, if they aren't working check your fuses as a blown fuse for the brake lights can can cause this seems to be a pretty common issue and most people have this happen just after using the towing electrics
Discodai Member Since: 16 Jan 2011 Location: Mid Wales Posts: 3 ![]() ![]() ![]() |
Thanks all. Brake light fuse was blown. All ok now.
![]() 1993 Discovery 200TDi owned from new 2007 Defender owned from 2010 1994 Rover Mini 35 owned from 1997 |
Limestone Member Since: 19 May 2017 Location: Cotswolds Posts: 2 ![]() ![]() ![]() |
![]() how could a brake light fuse cause so much trouble! amazing thank you bga86 ![]() |
proloFor�t Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
Limestone,
Thank you to find this for me. I have also this issue but no propblems with my brake lights. I now try to understand what is the "clutch switch" L�o |
L�o there is a thread on here that explains the Clutch Switch
here http://www.defender2.net/forum/topic579.ht...tch+switch and a post that goes
hope that helps ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20921 ![]() ![]() |
Failed clutch switch.
I've disabled mine completely, better drive without it and a better driver input. However, it isn't just a case of unplugging it on a Puma. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you for these replies and links. I am going to investigate this weekend.
Custom90steve, did you bridge the two wires? I am thinking of installing a "scotch lock" on these two wires will create the solution. |
Yes. Bridged.
You could use your method but if you buy the connector and bridge it like that it'll be fully waterproofed and the harness left in-tact. The connectors are only around �6, but maybe a little more fir you in France? I used a male and female, one to blank and seal the clutch switch socket. (Use sealed the wire entries at the rear.) And bridged with wire loop the harness plug and tied it away nicely. Throttle has a much better response, no MIL or DTC's. I've been running this for at least 500 miles now. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
These are the connectors, 2-way.
https://www.autoelectricsupplies.co.uk/product/680 Don't forget the pins and seals. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you. Good advising - keep the wiring loom unharmed.
I want to say thank you again for this tip!
The connectors arrived with me yesterday and I do the technique. The problem of the revs is completely gone now and it is much better driving experience! I recommend all people with this system do this fix. merci. ![]() |
