Home > Puma (Tdci) > TDCi Mpg's
Page 7 of 13 <123 ... 678 ... 111213>
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
Clive
Thats just as mine has been, I'm hopping that the fuel pressure valve have sort or the engine going into crazed rattle mode, has been ok over the weekend but didn't do that many miles so will see how it run this week will let you know how it run's
Dave
Post #5534 15th Dec 2008 9:48pm
alantd
Just completed a year with mine.
Although it gets used every day, it doesn't more than a couple of long trips a week. Done about 7k miles.
Pretty consistent economy at 25-27mpg. Off road that obviously dips to around 15-18. My previous Td5 did considerably better in similar conditions but it was a 90 and not a 110. I was hoping the 6th gear would help more than it appears to.
Re: limp mode. I've had several occasions where, after setting off I find it impossible to get above 50. If I stop and switch off and on again it is absolutely fine. No warning lights. Mentioned to the dealer and they can't trace anything - i.e. no fault codes.
I wondered whether it might be an EGR problem: maybe more smoke on startup (or am I imagining it because I don't have cause to think about it until the problem has occurred after a couple of miles); loss of power...
The EGR used to cause problems on other Defenders with similar symptoms and 50 is a bit quick for limp mode.
Any thoughts?
Post #5538 15th Dec 2008 10:02pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Any thoughts?
I've got my EGR semi-blanked off, basically it has a blanking plate in with a 15mm hole thus reducing the amount of gas recirculated. I have claimed 33>34mpg on many occassions which alot of people have questioned but I do 350 miles per week on A roads and motorway.
I may have to start taking pictures of my fuel receipts and speedometer reading to 'try' and convince people!
Post #5553 16th Dec 2008 12:40pm
chalky
mine regularly sees 33 - 35 MPG
I had a VR6 Golf some 10 Years ago and it was widely acknowledged that units varied significantly in power and MPG consumption. DEFENDER XS CSW 08 TONGA GREEN
Post #5554 16th Dec 2008 1:10pm
The Boy
Any thoughts?
Crikey thats over 10 mpg more than mine. Embarassed (anyone wnana 2007 xs cheap for cash)
Boy
Post #5555 16th Dec 2008 1:46pm
MK
are these figures based on US or Imperial gallons?
Post #5556 16th Dec 2008 1:46pm
mrwoo
4.54 Litres
Post #5558 16th Dec 2008 2:02pm
MK
In that case mine does around 27.8 mpg on the highway just under 120 km/h
Post #5560 16th Dec 2008 3:41pm
chalky
No its in Imp Gal ? Why would it be U.S. Gal ? Are you from the states ? DEFENDER XS CSW 08 TONGA GREEN
Post #5565 16th Dec 2008 4:39pm
MK
No, Chile. I was living in the UK when I joined the forum.
Post #5571 16th Dec 2008 5:26pm
chalky
Ah !
That could confuse an idiot !
You should be able to figure it out over there via the amount between fills ? DEFENDER XS CSW 08 TONGA GREEN
Post #5572 16th Dec 2008 6:56pm
MK
chalky wrote:
Ah !
Not quite. People tend to EXAGERATE about their mpg-km/l, etc so it could have been either.
We use liters from the metric or SI system, which I guess was created for idiots
Post #5575 16th Dec 2008 8:25pm
jst
Lie - thats quite strong, i have just believed people maybe work it out wrong or dont quite get the jist of the fuel, side
ie i sued about 1/4 tank and did 5000miles there i must have done..... mpg
rather than actual fuel used Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5576 16th Dec 2008 8:28pm
Eduardo
Using our SI system and after 40.000 km with the right motor oil our 110 SW have a yield of 10 to 11 km/lt
thats in MPG 25.8 to 23.5. (1 KM/L = 2.35214583 MPG)
We use to calculate the kms from the last fuel feed and the total volume feeded until the dispenser mechanism cut it automatically. So Im quite confident of this number. Eduardo
Post #5588 17th Dec 2008 1:45am
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
I do exactly the same thing. Fill up to pump cut off and consistently get 10 -11 liters per 100 km.
Post #5589 17th Dec 2008 5:27am
