Home > Technical > Newbee question
nitram17
Newbee question
Is this normal?....when i switch the motor off there is an electronic motor sound(for about 10 -20seconds) coming from the back of the truck.I have only done a few hundred miles in the truck and I have not noticed it before.
I assume its the fuel pump (but its quite loud) so can anyone confirm it is the FP and if its working normally
Post #377026 7th Dec 2014 1:29pm
landy andy
What engine?
Post #377028 7th Dec 2014 1:48pm
JAY BOY
Wales
2.2 i think Thumbs Up
Post #377030 7th Dec 2014 1:51pm
nitram17
landy andy wrote:
What engine?
2.2 puma 500miles
Post #377034 7th Dec 2014 2:23pm
landy andy
I think that they put a pump in the tank on the 2.2's, the 2.4's don't but am sure an adult will be along in a bit to confirm.
Andy
Post #377036 7th Dec 2014 2:29pm
bob neville
Mine does the same so don't worry - unless both of ours are broken Rolling with laughter
It appears to be the fuel pump in the rear tank. Easy to check if your sound is coming from there, sit in the vehicle and turn the ignition on and then off after a couple of seconds and you will hear the pump running on for 10 to 20 seconds before it stops.
2013 Defender 90 CSW - sold
Post #377038 7th Dec 2014 2:41pm
nitram17
Thanks bob!I am a bit paranoid as ive done 500 miles and nothing has fallen off,leaked( Censored Censored Censored flip i hope i havent jinxed it now)or broken............fingers crossed Exclamation martin.........ps ive used flip instead of Censored
Post #377060 7th Dec 2014 4:26pm
