![]() | Home > Td5 > Heat gauge reacting to throttle response. |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
Here is the video of what happens.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Bad earth??? Block to chassis / body
I would go with bad earth , or there used to be voltage stabiliser on the back of the gauge cluster that could effect the needles but normally would effect fuel gauge as well but also now days alternators are a bit smoother output then years ago , so I would start with earths checking
also might be worth checking alternator voltage, just in case |
Well I got to the bottom of my fault that was causing my temp gauge to fluctuate with input from the accelerator, it only took a month and a half.
And it was?
Come on spill the beans!
Brendan |
Haha, so I was installing a new LED light bar and red bison boomslang headlight loom, when running wiring through the bulkhead just behind the dash through an existing grommet and that's when I noticed two wires just behind the brake booster on spade connectors were apart which I connected up and forgot about it, I didn't think anything of it but when I went to test the light on a wee drive, low and behold no more fuel gauge rev counter 👍
So the earth terminal on the bulkhead was off?
well according to the workshop manual this isn't a recorded earthing point, the earthing point is on a ring crimp bolted to the firewall, so I have no idea what this is for!
