Home > Maintenance & Modifications > No main beam
Cheshire Dave
No main beam
Main beam suddenly not working it has been
On switching on lights to first click down lights work, switch to 2nd position nothing works no head lights or side lights
About a month ago the clock stopped working but now it started working again but lights are not when on second click down!
Any ideas as to the course
Dave
Post #376327 4th Dec 2014 2:01pm
Horn working still?
Post #376328 4th Dec 2014 2:02pm
Cheshire Dave
Yes
Post #376329 4th Dec 2014 2:02pm
munch90
headlight switch ? . quite common unless you have rewired with relays
contacts melt the plastic around them in the switch
Post #376332 4th Dec 2014 2:21pm
Cheshire Dave
I must admit there was a strange smell but didn't smell like plastic
Post #376338 4th Dec 2014 2:57pm
ickle
They're not made from plastic that's why they melt - best guesses are old porridge, did it smell like a Scotsmans breakfast gone bad?
Keith
Post #376341 4th Dec 2014 3:34pm
Cheshire Dave
Never thought of a Scots breakfast !!!! But could have been!
Is replacing the switch an easy job to do or should I leave it to someone who knows better ?
Dave
Post #376353 4th Dec 2014 4:11pm
What Munch said Thumbs Up
Happens to everyone sooner or later, unless you rewire the headlights to use those newfangled relay things.
If it isn't the main light switch that has failed (the most common failure, and easy to replace) it will be the dip switch (not so easy to replace). If it's the main switch you will get the symptoms you describe, ie sidelights OK, but nothing with the switch in the headlight position. If it's the dip switch usually you'll have either dip or main but not both working.
As an emergency work-around, if you have or had dim dip, you can short out the dim dip resistor (so the dip beam comes on at full power with sidelights), alternatively remove the steering column shroud, cut the wire leading to the failed switch as near as possible to the switch, and connect all three wires together. This will give you side and head and allow you to continue your journey.
Been there, done that, more than once (I now carry a spare switch). I really must get round to fitting relays!
Post #376367 4th Dec 2014 5:04pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I thought my main beam was broken the other day, but discovered I only had the light switch on first click, with relays installed the electrical current is enough to activate the relay so it gives the impression they are on second click.
It could be that your resistor has failed and is giving 100% to the bulb on first click, main beam wont work on first click Thumbs Up
If it's the switch, changing it is a 5min job.
Post #376387 4th Dec 2014 6:45pm
Took me a while to work out what you mean! Do I take it that you have upgraded your headlights to have relays but still have a dim-dip resistor fitted?
If so, I have to ask why?
Post #376393 4th Dec 2014 7:00pm
Cheshire Dave
I can flash the main beam on as if flashing an on coming car
Dave
Post #376403 4th Dec 2014 7:20pm
munch90
The flash is done by the indicator stalk independent of the main switch , so still say main switch to check first
then relay to stop it happenning again
Post #376419 4th Dec 2014 8:02pm
mrd1990
There is no need to remove the resistor when fitting relays as it does no harm, the resistor only works when the ignition is on and light switch on the first click.
With relays, when light switch is on first click and ignition on it activates the normal headlights but the main beam wont work unless the light switch is on second click. Thumbs Up
Post #376420 4th Dec 2014 8:02pm
munch90
only thing is there is no side lights only when ign on for mot , if you still got dim dip resister fitted when you fit relays
cant think if that's a mot fail or not ????
ok the sidelights work but so do headlights on first click ??? not sure about that for mot, not quite right but also bit wrong not sure on that one !
Post #376431 4th Dec 2014 8:33pm
mrd1990
I believe having the headlights work on a resistor was an old law which is no longer relevant:
It passed it's MOT without problems,
Position 1 with no key = Side lights
Position 1 with key = Side lights + Dim Dip
Position 2 with key = Side lights + Dim Dip
Position 1 + Main beam = Side lights + Dim Dip
Position 2 + Main beam = Side lights + Main beam
Position 2 + Main beam + Spotlight Switch = Daytime Cool
What my point was, if the resistor has failed in a way that mean it allows full current through, one could easily forget to use position 2 on the light switch which means the main beam wont work except for flash Thumbs Up
Post #376477 4th Dec 2014 10:32pm
