![]() | Home > Td5 > ARGHHHHH TD5 Immobiliser !! |
| randallised Member Since: 30 Apr 2012 Location: Doolin Posts: 18
Hi all any help appreciated.
The car did not lock on fob, had lunch then would not crank. Ignition lights on, but nothing on the key, engine crank warning light red with lightning bolt through it. No security card so could not enter over ride manually, I have this now. Picked up by AA taken to main stealer. Having been relieved of my hard earned, I was told the 10as unit was faulty. They replaced it with a new one. BUT that would not talk to the ecu at all and the stock unit will not programme. There is a white/ orange wire broken / cut from the AS unit ? No central locking or alarm they did however manage to turn the immobiliser off via dealer software. Prior to this the car would always blow flash / horn fuse under drivers seat. Fitted new horn and switch cluster still the same. Getting to the end of my fuse with this one. I am in the west of Ireland to boot. cheers |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Orange/White should not be cut!
1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks all. I will go at this next week at let you know what I find.
Cheers Matt |
| All times are GMT |
