![]() | Home > In Car Electronics > Dodgy aux-in jack on LR head unit? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Poor connection to the jack most likely, doubt repair is viable.
Used Defender HU's commonlylp sell for relatively low prices. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18018 ![]() ![]() ![]() |
One thing to check is that the diameter of the body of the plug isn't too big to allow proper engagement. The socket is recessed slightly in a circular recess and I used to find (before I changed the HU) that most plugs wouldn't go in far enough for a reliable connection.The result was crackling and one channel dropping out.
When I eventually found a lead with an unusually small plug body all was OK. Failing that it could be dirt in your socket, or a dry joint between the HU connector and pcb, neither of which can really be dealt with easily. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
as blackwolf said you need a small diameter plug body to fit properly DEFENDER 90 TDCI XS,
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 ![]() |
I had the same problem on my 2012 2.4. Tried multiple leads and all were the same. I should have persevered with getting it fixed under warranty.
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
If it isn't a mechanical issue due to the size of the plug, I would try a little squirt of electronics switch cleaner or a blast from one of those aerosol air dusters down the hole before writing it off. As blackwolf says it could be dirt or dust that has got in there.
