![]() | Home > Technical > Front doors - remove pin? |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
On my ones there is a split pin you pull out then withdraw the pin on the bulkhead end of the door strap.
Keep an eye out for any washers that may be between the pin and the strap. You may have a plastic cover over it but this should be simple to remove. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
| mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266
I did this a few months ago:
http://defender90xs.blogspot.co.uk/2014/08...seals.html The removed pin can be seen about half way down the page. http://defender90xs.blogspot.co.uk/ |
| eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586
Thanks for the help guys!
mark_d - this is exactly what I'm hoping to achieve, your blog is a great reference for the seal replacement. thanks! |
| All times are GMT |
