Home > For Sale & Wanted > [Wanted] Relay holders
rallysteve
Hi all.
I am after a couple if relay holders for my 110. The ones I am after are the ones the yellow relays live in directly under the fusebox. I have universal holders but want a couple of the proper ones which clip onto the bottom of the fuse box surround. Dont really need wires with them, just the plastic casing.
Can anyone help please?
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #373936 24th Nov 2014 4:58pm
K9F
Any good?
http://www.autosparks.co.uk/index.php?cPath=95_771 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373972 24th Nov 2014 7:45pm
rallysteve
Cheers but they are like the universal ones i have got. Would rather use the matching (yellow?) Ones which clip onto the metalwork. 02' 110 TD5 Double Cab Rebuild Thread
Post #373985 24th Nov 2014 8:30pm
K9F
Scrap dealers perhaps? I wanted an OBD connector and got one from an old Jaguar that had past it's sell by in the yard. Relay bases should be in abundance somewhere like that.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #374039 24th Nov 2014 11:30pm
munch90
search ebay using "lucas rist"
eBay item number:
eBay Item No. 131074821233
Post #374040 24th Nov 2014 11:38pm
Vince VDB
France 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
Many thanks to indicate this eBay seller, its perfect for me Thumbs Up Defender 110 Puma 2.4 SW SE
Defender 90 300 Tdi SW with TD5 body
Land 90 V8 HT
Post #374062 25th Nov 2014 1:47am
Martin
Site Admin
The Lucas Rists ones are the originals Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #374098 25th Nov 2014 9:54am
rallysteve
Great cheers,
Just what I was after! Very Happy
Post #374293 26th Nov 2014 2:24pm
As a follow up to the OP's query, does anyone know a source of the metal brackets that Lucas Rists type relay holders fix to, either individual tabs or a generic multi-tab bracket such as this overpriced one on Ebay?
For some reason the tabs only appear to be available with generic type relays, not one their own, and I cannot find anyone who lists a generic multi-tab bracket.
Any leads will be gratefully received!
Post #377532 9th Dec 2014 1:23pm
K9F
Blackwolf,
Have you considered visiting Charles Trent and scrabbling around a few of their vehicles? I can normally get any electrical bits 'n' bobs successfully sourced from there!
Post #377534 9th Dec 2014 1:32pm
Martin
Site Admin
Not that it helps you now, but there are Rists holders with brackets moulded to them available from that eBay seller Confused
There are various brackets available from LR for 1/2/more relays, from different vehicles. Whether these will fit the Rists bases, I'm not sure.
But a few part numbers might get you started Wink
AMR3134 (5 position?)
PRC7140 (3 position?)
PRC7054 (2 position?)
You might also find something on an MG/Rover which also used Rists components?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #377537 9th Dec 2014 1:38pm
Martin, many thanks. AMR3134 might be perfect, but do you have any idea what it actually looks like? None of the suppliers have an illustration (but at under £3 it is more attractive than the ebay classic Rangie bracket I linked to).
Mal - normally I'd do as you suggest but just at the moment I simply don't have time due to pressures of work. I can't get there except at a time when the guard dogs would see me off with a punctured backside! Shocked
Post #377566 9th Dec 2014 3:03pm
Aha, answered my own question!
http://lrcat.com/32/4/45398
Perfect, many thanks!
Post #377568 9th Dec 2014 3:05pm
Martin
Site Admin
Let us know how you get on, whether what turns up is what's in the picture Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #377571 9th Dec 2014 3:22pm
Will do, thanks for your help!
it does seem strange that no-one seems to make a simple, off-the-shelf generic bracket. The relay bases are ISO standard and the tabs are the same for the bases or for the integral slot on an ISO relay itself. I was expecting the kit-car suppliers to have these things falling off the shelves, but apparently not.
Perhaps there's an opening here for an enterprising laser-cutting, metal-bending small business.
Post #377574 9th Dec 2014 3:38pm
