Home > Maintenance & Modifications > Terrafirma Lift Kit
Nick Taylor
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Terrafirma Lift Kit
I am considering fitting a Terrafirma All Terrain Suspension Kit for the Defender 110/130 Medium Load, I am after your thoughts, comments or experience on fitting. Look forward to hearing the good, the bad and the ugly...
Post #373486 22nd Nov 2014 4:11pm
landy andy
I would not touch Terrafirma suspension. The quality is poor, and the life is very short. I've brought, fitted it, binned it, replaced it.
Sorry
Andy
Post #373500 22nd Nov 2014 6:01pm
Nick Taylor
Hi Andy,
Thanks for letting me know, what did you replace with?
Nick
Post #373503 22nd Nov 2014 6:12pm
landy andy
Old man emu. Not cheap but great kit, very stable and lasts.
Koni is also very very good but dampers only you would still need springs.
Andy
Post #373515 22nd Nov 2014 6:53pm
Nick Taylor
Cheers Andy, will Google both...
Nick
Post #373516 22nd Nov 2014 6:55pm
robertcoby
I fitted + 2" lift terrafirma kit and it's great glides over bumps and corners are sure footed
Post #373638 23rd Nov 2014 9:29am
robertcoby
Sorry should add it's light duty kit
Post #373640 23rd Nov 2014 9:30am
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
Robert, sorry to resurect a thread from so long ago but can you comment on the ride heigth being a light duty kit? - from my understanding the HD kit will always sit slightly higher than a light duty kit or am i wrong?
Post #977597 11th Jan 2023 3:56pm
robertcoby
Hi i don't think there is any difference in the height of the lift but if you dont carry much goods the light lift is ideal. I just used mine like a car and handled great. I fitted police spec range rovers once and they were far too hard considering all the equipment they carry.
Regards Robert
Post #977692 12th Jan 2023 10:42am
Will.I.AM
thanks pal, that helps. I made the rookie mistake of buying the cheapeest lift kit many years ago which happened to be a HD sh13part lift kit for a 90 and you would end up with a migrain everytime you went off road as it was so hard.
my 130 has a HD kit at the moment and i am considoring putting on soft lift springs and maybe a 1 inch lift block too to give it a 3 inch lift and retain a nice ride still.
Post #977693 12th Jan 2023 10:46am
