Home > Puma (Tdci) > Stainless Exhausts?
SS90
Stainless Exhausts?
What's the exhausts like on the Pumas, anyone changing them over to a stainless from new?
Post #373467 22nd Nov 2014 2:31pm
K9F
Depends really on what you are trying to achieve. Puma exhausts are generally well made and dependant on useage of the vehicle under normal conditions should perhaps last maybe 7-10 years. If the vehicle is a 'keeper' and you wish to alter the configuration a stainless steel one is well worth considering as many will offer you a lifetime warranty. If you're happy the way the vehicle currently is don't bother and spend your money on something more useful.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373475 22nd Nov 2014 3:24pm
Likeomg
If your a naughty boy and remove the cat at the same time you can get a rather sweet sounding note, there's a vid of mine floating around somewhere on here it's alives full system
But let's not start the cat discussion as its been done to death elsewhere
Post #373485 22nd Nov 2014 4:00pm
I'd go for Alive's myself if I did. CAT or not you can go for a CAT back which is what I'd probably do.
Easy to fit as well.
Issue with mine is having a TF centrebox which is a poor fit. Big Cry
Post #373494 22nd Nov 2014 5:18pm
pannawonica
Australia
Plus one for aAlive exhausts! Thumbs Up
Post #373622 23rd Nov 2014 3:56am
LR90XS2011
ditto don't waste your money on TF centrebox replacement pipe DEFENDER 90 TDCI XS,
Post #373629 23rd Nov 2014 7:56am
