Home > Maintenance & Modifications > Window blanks/covers
Stuarta
Good evening all,
I've done a search but can't find what I'm looking for. I'm trying to find out if anyone makes window blanks/covers that can be fitted inside the rear and side windows of a Station Wagon (I guess it doesn't matter whether 90 or 110) in order to keep prying eyes out. I've currently made some from silver-backed bubble wrap but it looks a little DIY although similar in appearance to the window blankets motorhomes fit inside their windscreens (see pic).
Obviously I could go down the tinting route but would like a removable option. It wouldn't be too hard to cut some from thin plastic but a purpose made solution with suckers or suchlike to attach them to windows would be good.
Post #372289 17th Nov 2014 9:42pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
We drove to Belarus in the summer with a very fully loaded 110 and I just cut some mdf to slot behind the rear seats to blank out the glass, but more to prevent stuff breaking the glass and falling out on to the autobahn than to prevent prying eyes. Easy to slot in and remove. Rear windows are a bit more awkward but a piece of mdf across the car would serve a similar purpose. Total cost £0 as I had the wood in the shed. Constructed by Messrs Heath and Robinson Wink
Post #372304 17th Nov 2014 10:22pm
knrv8
1989 Defender 110 V8 Petrol CSW Cairns Blue
Post #372464 18th Nov 2014 1:28pm
SailingTom
If it was me personally doing it Id do like on our boat.
As said cut some ply to shape covered in carpet and hold in with 2 toggles on the trim. That way you can take them out and put them under the rear mat when not in use.
would look neat to Smile Defender puma dormobile camper
Post #372468 18th Nov 2014 1:50pm
Stuarta
I like the thin ply idea and could spray/paint the reverse (window) side black to look 'tinted' from outside. Silvered material (like motorhome blinds) draws attention to the fact that there might be something in there!
Post #372473 18th Nov 2014 2:08pm
gilarion
Have you thought of anything like this from B&Q the perforations are tiny it would also give the illuison that they were security grills.
http://www.diy.com/departments/steel-panel...326_BQ.prd perforated steel perforated panel
Post #372482 18th Nov 2014 3:06pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
My 110 has pre-proper-utility blanked off windows- but I am guessing you are wanting a quickly interchangable option. Im planning on dropping a set of 88in van sides in instead.........
Chris
Post #372514 18th Nov 2014 6:47pm
