![]() | Home > Puma (Tdci) > 2.4 won't start!!! Please help. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Checked for DTC's?
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
It sounds as if the EMS is not receiving a mobilisation code from the IPAC. Remove the drivers side speaker adjacent to the fuse cover. Have a look up towards the windscreen and see if you can spot a green box. If it is present then the Puma has a 10AS module but it may not have any settings enabled. If the 10AS is present hook up a diagnostic tool and check the settings page to see what is enabled. There is a way to bypass the immobiliser but I will need to chat with you as you are new on here about that as I am not posting how to on a open forum.
| Midwaleslandie Member Since: 17 Nov 2014 Location: Wales Posts: 5 |
Thanks for the replies.
I'll remove the speaker now and get back to you in a jiffy. I have already plugged in our Autel maxidas but can only get into the PCM with that which didn't bring any fault codes up. I'll check now and get back to you. Thanks again. |
Okay. Speaker removed and indeed I have a green box with 10AS written on it. I've hooked our machine up to it again but still can't get into any settings.
Not really sue where to go from here as the nearest L/R dealership to us is about 58 miles away. |
To access the 10AS module with a diagnostic tool the ignition needs to be in the off position. Not sure about the Maxidas but my Autel tool does not cover the Lucas 10AS module. The only tools I have which do are JLR SDD, Nanocom and MSV2.
I tried that but to no avail.
However, I removed the circuit board from the green box, cleaned up a few connections, sprayed with wd40 and turned the key but not expecting much. But, it started!!!!! Still no flashing light but it now starts and runs. Strange. |
One of the members on here had the same issue. Turned out to be pin contamination on the 10as from a leaking windscreen.
Well it may just have been that. Now wrapped in a sealed bag
Thankyou for your time and input, wouldn't have even found said box without your help. Much appreciated |
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
I so love this place...
Even a complete stranger to the community is responded to in next to no time when in need of assistance and treated with complete respect throughout... Kudos to this site and, in this case, to @Lorryman100 specifically... Hopefully, we will now have another convert and D2 member in @Midwaleslandie too... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
