Home > Puma (Tdci) > Puma Gearbox Losing Oil
Discodai
Wales 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Hey. Just had to refill 2007 2.4 Puma gearbox again. Can't find any leaks anywhere and only filled it in August, about 3,000 miles ago. It was almost completely empty. Any ideas?
Post #369761 5th Nov 2014 6:11pm
dgardel
Italy
How do you check the oil level?
You can not use the filling hole like a level check, but you must discharge the old oil and refill the gearbox with the predetermined quantity..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #369764 5th Nov 2014 6:19pm
mk1collector
Also if you did fill to level at the wrong plug it could be seriously overfilled
Post #369782 5th Nov 2014 7:54pm
landy andy
If it has gone, I assume you can't see leak, have you checked transfer box level?
But as above, filler plug is not the fill level.
Andy
Post #369850 5th Nov 2014 10:35pm
munch90
No way for it to get in to transfer box
if the output shaft seal leaks it will leak in to adaptor casing between main box and transfer box and the adaptor/extension casing has a drain hole as its a dry casing ( where the spline is that wears ) , so oil would leak on to ground
Post #369854 5th Nov 2014 11:08pm
