Home > Puma (Tdci) > Rear window brake light mounting
Landyawd
England 2011 Defender 90 Puma 2.4 HT Java Black
Hi all,
This maybe a silly question of one that has been answered before. If so I Apologise in advance!
I have just purchased a new back window for the rear door of my my11 defender 90. However when I went to fit it I noticed on the old window there are two metal threads glued to the original window to mount the rear brake light. On my replacement window these metal threads are not there....
Does anyone know the part number or where I can get them from? I presume they are glued on using some sort of impact glue?
Post #369181 3rd Nov 2014 11:31am
gilarion
There are two types of back door glass one that has the tags fitted for the high level brake light and one that does not. It appears that the glass you have is the type that does not accommodate a high level brake light. You cannot stick on the tags I am afraid. The part number for a back door glass with high level brake light is CBQ 101560
Post #369183 3rd Nov 2014 11:44am
Landyawd
Oh dam it!! Big Cry
I got it from Masai, it has a marked area for the tabs and the black but for the brake light surround but there are no tabs!! I will give them a call and see why and what
Edit: for my awful spelling!!
Post #369186 3rd Nov 2014 12:22pm
mk1collector
Remove the ones from your old window and take them to a window fitter (auto glass etc) slip a fitter a fiver to prime and stick the tabs on. Make sure you take your brake light though as they will need this to get them in the right place.
Post #369205 3rd Nov 2014 1:45pm
gilarion
Will that work as the live and earth for the brake light are taken direct from the heated rear window filament if there is no filament on the glass that Ladyawd has bought how will it work?
Post #369227 3rd Nov 2014 3:30pm
mk1collector
The rear brake light kit that massai sell just comes with glue to stick the studs on so I presumed they just touch the contacts when stuck on.
Post #369228 3rd Nov 2014 3:47pm
Landyawd
I have confirmed I have the correct window, in other words the circuitry for be brake light is on the window along with the outline of the brake light.
However no posts to mount it too.
I have now been told this is a separate part (part number: AWR4647)
I have tried getting the originals off the old window but they will not shift without bending them and possibly busting the old glass.
Looks like I best get ordering!!
Thanks for the advice peoples Bow down
Post #369229 3rd Nov 2014 3:48pm
gilarion
This is the part and a Microcat image.
Might be being thick but I cannot see how this stud conects power to the brake light though.... Item 6 is the stud on the Microcat image.
Post #369233 3rd Nov 2014 4:21pm
gilarion
Sorry I think I have the wrong end of the stick are you saying that you have the two tags that the lucar connectors fit onto to provide power and earth and that what is missing are the two threaded lugs to facilitate the fixing of the Brake light unit to the window if that is the case then those tags are what you need.
Post #369235 3rd Nov 2014 4:40pm
Landyawd
That's it, there are two studs that should be on the window. As your picture shows. They are only for mounting not the circuitry
The connectors for the circuit are printed on the window so no issues there
They are part number AWR4647
Perfect thanks gilarion !!
Post #369304 3rd Nov 2014 10:33pm
Tiger
Where in Surrey?
I have a window with them on here that you can have. (And smash Thumbs Up )
(Not in Wales)
Post #369310 3rd Nov 2014 10:48pm
Bristol 90XS
The rear window from Landy glass fits in a few minutes....
Post #369334 3rd Nov 2014 11:53pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Stuck mine on with Sikkaflex and they've been on for a year with no issue
Post #369335 3rd Nov 2014 11:59pm
Landyawd
Tiger wrote:
Where in Surrey?
(Not in Wales)
Hi tiger normally I'm near woking Surrey but I am over in France at the minute for a few weeks, thank you for the offer though if i get stuck I might take you up on that offer! Thumbs Up
Post #369362 4th Nov 2014 7:38am
Landyawd
Thanks epictrail, I will see if I can get some. I was wondering what sticky stuff would be best, I was going to go the contact adhesive route like Evo stick but is guess it's not really under a lot of pressure the unit is quite light (in weight!)
Post #369363 4th Nov 2014 7:42am
