![]() | Home > Puma (Tdci) > Puma Question |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Tony
Sounds a bit like mine before Yeovil LR did the software upgrade before christmas - apart from the first bit about the inlet duct. More than happy for you to come and have a drive in mine to compare - if that would help. I am between Taunton and Ilminster. Bob |
| tony2 Member Since: 01 Apr 2010 Location: Taunton, Somerset Posts: 26
Many thanks Bob, that would be very usefull to make a comparison.
When would you be available ? and if you could let me have your address and postcode I can shove it in the old Sat Nav.....TC. Its easy to smile and be happy when the world rolls along like a song. But a mans got style if he can smile when his Land rovers going wrong. |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Tony2....I had a similar rattle and i turned out to be the heat shield over the exhaust / turbo at the top drivers side of the engine......silver shield.... have a look there...mine had a bolt loose.... but simler type of rattle to yours
Cheers Fekete, will check it out tomorrow
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286
When I first got my 2007, the bracket holding the heat shield had snapped. 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
Tony PM sent Bob |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
yer mine had broke as well i took it off for a while as i was fed up with the rattle and waiting for LR to get a new one i even thought about tiging it but its monkey metal 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
my intake used to make that noise as do most of the new ones i have come across - it seems to go with time, as the bit probably wears through and falls off!
Are you into greenlaning? you should come out to play with us, quite a few Taunton way on here. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Hi JST.
Thanks for the info, will check a few things suggested tomorrow, if no good will wait for whatever it is to fall off Haven't done any green laning as yet, but definately interested in having a play. Cheers.............TC. Its easy to smile and be happy when the world rolls along like a song. But a mans got style if he can smile when his Land rovers going wrong. |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Both mine did the same,, intake noise, but not noticed after the RAI were fitted California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
