- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Lotus_esprit_s1
[Wanted] Td5/TDCi Defender 90 standard fuel tank guard | |
I need the fuel tank guard for a td5/TDCI 90 - the folded steel plate that bolts to the underside of the chassis to locate the fuel tank. Nothing fancy, just the standard factory fitted one will be fine.
There must be a spare one somewhere sat unused in the garage or behind a shed which has been removed when a heavy duty guard has been fitted.
Thanks.
27th Oct 2014 5:51am |
