Home > Maintenance & Modifications > Bent Steering Bar
CFB
Bent Steering Bar
Managed to bend the steering bar on the 110 yestderday doing a spot of off-roading, knew I should have fitted a steering guard Sad
Only a small kink in it but as a consequenece the steering is all over the place. Question is can it just be bashed straight or will it be weak and thus need a replacement?? Andy
Post #31841 10th May 2010 10:15am
Grockle
staighten it in a vice carefully Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #31846 10th May 2010 11:14am
CFB
Is it a hollow tube rather than a solid bar? Never taken one off so unsure? Andy
Post #31850 10th May 2010 11:25am
alantd
Personally I'd replace it. The steering's bad enough and you'll be forever questioning whether it is down to your bent rod (*ahem*) or an inherent trait of the vehicle.
Lesson for us all - steering guards are a must have. One that started out as a 2.4 TDCi 110 XS
Post #31861 10th May 2010 1:17pm
MK
I bent mine a bit (behind the axle) and left it like that. No probs. Puma 110" SW
Post #31865 10th May 2010 1:26pm
CFB
I've seen a few 'heavy duty' ones advertised but at nearly a hundred quid!
I think a new standard bar with a steering guard must be a better option? Andy
Post #31866 10th May 2010 1:26pm
Glynparry25
I have the HD ones on my off-road discovery- they are solid steel bars that you can't bend- they say you don't need guards with them because of this. I have both on it as I like to be extra safe as it is a pure off-road toy.
Lesson to many owners to not just give lip service to under-body protection Wink Looks like you had a lucky escape as I have seel loads of people actualy snap them and end up stranded.
If it is a slight bend (jut a cople of degrees) you can get away with doing tracking and carrying on....but if it needs straightening I would just get a new one, as said befor it is jus a little bit of flimsy steel tube that is only designed to have a lateral force on it so it may even have cracked underneath paint.
Glyn
Post #31868 10th May 2010 1:55pm
110SEB
Our Rebel 4x4 steering gurard was relatively cheap and is as solid as a rock. Splashed out on a QT diff guard though. Worth it simply for peace of mind if your truck does venture off the black stuff (which all of the forum's trucks do I imagine).
Post #31869 10th May 2010 2:14pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
I bent a heavy duty track bar and thought it would be fine but it started to eat my tyres because it was scrubbing badly!! just change it, thats the only way you can be 100% sure everything is correct Thumbs Up
Post #31898 10th May 2010 6:35pm
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Do not be tempted to use heat to help straighten it, it will be spotted on the MOT when it comes round, it is a failure issue, and it weakens the strength of the rod / tube.
I did it to my TD5 replaced the whole thing including Track rod ends, best as someone says safe rather than sorry.
Tommy Tommy
110 XS TDCi
Post #31927 11th May 2010 5:30am
leeds
An in the field solution is a strap around the bar and a gentle pull as a get you home solution.
Long term solution is a replacement one especially as they are not that an expensive part.
To protect or not? Depends what type of driving you do. Only occasional gentle green lane then maybe not.
Choices of protection are dan/sumo bars which strengthen existing bars. Ensure they have grease nipples on. Protects both forward and reversing
Steering guards. A large selection, steel, alloy, recovery eyes, no recovery eyes, 2" receiver, galvanised or electroplated. Then there is the argument of steering guard being a plough especially when reversing in deep gloop. One reason why the comp boys are not so keen on them!
On our red 110 we have belts and braces Laughing
Galvanised or electroplated? Electroplating is cheaper and has a much thinner coat on and passes a much shorter salt water test. They will start to rust after a while especially from the edges. That is the type we have on our Disco!
Steel v alloy? Weight v cost!
Recovery eyes or not? Easier to get to then Jate rings especially when you are in deep gloop. Good recovery points bumper mounted even easier! 2" receiver means recovery billet can be switched to a tow ball if needed.
The weak point are track rod ends. Steering guards/dan bars do not fully protect these. However steering guards limits do offer some limited protection as they limit the gap available.
Do not buy cheap ebay specials though. A friend of mine did, after less then a year and about 6 recoveries at local club RTV's this was the result
On both sides! None of the recoveries had been 'hard' recoveries!
Buy cheap pay twice over
HTH
Brendan
Post #31937 11th May 2010 9:34am
