Home > Puma (Tdci) > Grumbling noise when slowing down.
Lloydy 7
England 2010 Defender 110 Puma 2.4 SW Zermatt Silver
My 2010 110 XS makes a grinding noise with a vibration when slowing from 75mph to 65 mph. It doesn't happen at any other speed. I can't pinpoint the source of the noise other than somewhere in the drive train. Anyone had this ?
Post #366161 21st Oct 2014 2:31pm
landy andy
Check front diff, if early 110 it will have the weaker two pin (stupid name as has one pin) diff init.
You can check it if you use a torch via the filler hole.
This is what I found
Spot the one pin, that now is a two pin.
Apart from that grease props and see if it alters vibration.
Post #366168 21st Oct 2014 2:44pm
Lloydy 7
Thanks Andy, I'll have a look. Have greased props before posting this but no effect.
Post #366171 21st Oct 2014 2:59pm
