![]() | Home > Td5 > Defender on the motorway ! |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
YOU need a transfer box change and a mild remap
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Whats wrong with my transfer box ? I works ? it transfers as far as I know hahahaha
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5138 ![]() ![]() ![]() |
Just a suggestion and before you do anything Else check you have not got rubber matting or carpet under your throttle pedal that is stopping the pedal achieving full travel, quite a few people complaining about lack of power find that is the cause
It is a while since I had a TD5 but I could easily get the speed you mentioned and the Td5 90 would tow a caravan easily at seventy , not that I ever did !!! |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I have a totally standard (in terms of engine and gearboxes) Td5 in standard tune and usually cruise at 55, occasionally 60. It seems happy there. Anything above that and it sounds like it's starting to scream a bit. I do intend to change to Disco transfer gearing and get it remapped, but It's some way down the list! 2005 Td5 | 90 Station Wagon | Tonga Green
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Definitely worth looking into, I've done mine and it makes motorway and general driving much nicer, as long as you don't intend doing too much towing. I'd check that everything was running ok though as a normal Defender should reach 70 fairly easily. Check the MAF is clean, air filter is clean etc. A bigger intercooler won't make a massive difference unless you have a remap, I changed mine to a Serke fast road, remapped and changed the transfer box to 1.2 rather than 1.4 and it now makes it lovely to drive on any road, much better economy, quieter and just nicer. |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 ![]() ![]() |
I concur, 70 is a bit of an effort for my old girl. It'll do it without too much drama, but doesn't seem totally comfortable. On a quick run over the A68 trying to keep it at 60 up and down hills, with four in it and some kit on the roof, the fuel guage takes quite a dive!
Saying that a 100 mile round trip, yesterday, cruising at 50, returned around 34 to the gallon, brimming it before and after the run. I was very impressed, or my maths is very wrong. 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel. 2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
Try again without the snorkel connected, they can be quite restrictive
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 435 ![]() ![]() ![]() |
hi, i find 70 is a normal and sociable speed as i have changed the tranny cogs for the disco 1.22 ratio. Travelling at 60 now gives me over 30mpg even when towing and 70 still returns a 28/30mpg roughly. top speed down hill is now off the dial too!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5987 ![]() ![]() |
Mine used to fly, 70-80 cruise no problem with alive stage 1 and disco gears. But it was the remap that made the difference, the remap also made the high speed quieter than the disco gears did, they just helped further. I was running mantec snork and would pull all the way to 100mph with no problem running mud tyres, winch and bumper, full roof rack.
And I miss it ![]() ![]() ![]() Andy |
another green oval rocket on the A10
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
I found my Td5 110(bog std.) @ 60-65mph to be right in the "power band"
![]() Roverdrive, intercooler,twin air intake & Alive map...... makes life a little easier ![]() Mpg is up too ![]() ![]() ![]() |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Mine likes 65-70 although drinks more fuel.
![]() 75 and it's screaming its transfer box off! 80-85 is it's flat out speed and it's not a happy place for more than a few seconds ![]() Standard TD5 ![]() |
CARMARK2014 Member Since: 28 Dec 2013 Location: SHEFFIELD Posts: 57 ![]() ![]() ![]() |
My old TD5 liked cruising at 55mph to 60 mph but when asked it would reach 80 plus but very noisey with bk Goodrich mt tyres.
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Mine will cruise at 75-85mph happily all day, disco tranfer box and stage 2 JE tune
