![]() | Home > In Car Electronics > Battery connections |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
That wouldn't be enough for a winch or jump leads (via an anderson cnnesctor under the bonnet) though would it?
I have been looking for the same myself, the Discovery 4 has a bus bar type strip of metal coming off the post that everything bolts to, I just can't find anything remotely similar anywhere. 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
no where near heavy enough for winch etc
really you need to be looking at marine industry for the type of thing you want |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
You could fit something like I have 👍
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
All got from Tim sponsor on here
Op didn't say anything about a winch.......
third post down mentions winch no good for that sparkylee's looks the thing to have |
Oh yeah, but the OP doesn't. So the product might suit post one, but not post three, which followed my post. I am all caught up now!
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Something like that from Blue Sea...
![]() Click image to enlarge Can handle up to 600A... http://www.amazon.com/Blue-Sea-Systems-Pow...ea+bus+bar There are others with more bolts to handle up to 150A http://www.amazon.com/Blue-Sea-Ampere-Comm...ea+bus+bar Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
Sparkylee, that is a neat solution. Have you re routed the main negative lead to the bus bar, and then added a link cable from the bus bar to the battery? The battery terminal connector on my negative lead does not make it easy to connect any additional leads ( unlike the positive lead connector ). I guess I would just need to cut off the existing terminal connector and crimp on a ring connector. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
From memory I think I cut the - cable and routed it on to bar far right hand side then to battery
It has a strange terminal for the connection to battery so wanted to keep it I did look into buying a complete - lead but too much £££££ for a 1m lead so if you do cut it be careful it is short. No length for a second cut ![]() These are them, the heavy duty ones http://www.mobilecentre.co.uk/index.php?ma...=&dto= Looking at the picture I could have got them level ![]() From these I'm running the winch via the cut out switch mounted through the front of the seat box and also the Anderson connector also mounted on the seat box front for the jump leads which again came from Tim It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
5th/6th items here: http://polevolt.co.uk/acatalog/Battery_Terminals.html
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Lee,
Confused by that pic ;-? How come you have a big fat red wire attached to the battery box? ?? |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
^^^^ I was wondering that too...!
Must be an optical illusion.... ![]() Cheers Simon |
