Home > Td5 > TD5 fuel filter housing
excossack
Is it possible to buy the clip that the housing cover attaches to on its own? See link below
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...2340564f46
Is the bit in the blue circle (it rusted away)
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #364717 15th Oct 2014 7:08pm
jimbob7
Are they not just a Dzus fastner?? Pov.spec,ftw. 2006, 110,TD5.
Post #364724 15th Oct 2014 7:33pm
excossack
Err not sure as I have not used Dzus fastenings 1999 Defender TD5 110
Regards
John M0VAZ
Post #364728 15th Oct 2014 7:39pm
jimbob7
1/4 turn fasteners,like these.
http://www.ebay.co.uk/itm/Genuine-Dzus-Mot...1e72f45180 Pov.spec,ftw. 2006, 110,TD5.
Post #364729 15th Oct 2014 7:41pm
excossack
That looks like the badger - cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #364732 15th Oct 2014 7:43pm
jimbob7
Thumbs Up Pov.spec,ftw. 2006, 110,TD5.
Post #364733 15th Oct 2014 7:44pm
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Comes in 2 parts if you just want the cover
Part number WKT100020 £17 from Craddocks I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #364835 16th Oct 2014 5:50am
Podrob
I would suggest drilling a small 3mm hole through both flanges and use a small tie wrap to secure. More reliable than the factory catch
Post #365779 19th Oct 2014 10:04pm
Martyn668
Brilliant timing. I took the cover off mine and then lost the fastener, so it hasn't had the cover on for a couple of months. Can anyone tell me what to select from the eBay options? Stud length is probably the shortest (15mm) I guess, but what about the receptacle? To be honest, I was just going to pop in to the stealership. They're usually helpful, and it will only be a couple of quid for this fastener, assuming it comes separately.
Post #366151 21st Oct 2014 1:26pm
basher111s
there's a special kit been set up with a black quick release Dzus bolt and clip here
http://www.ebay.co.uk/itm/Land-Rover-Defen...27ef98fe7d
Post #368337 30th Oct 2014 8:21pm
Martyn668
Nice one. Thanks for the link.
Post #368423 31st Oct 2014 1:06am
Turbotcharged
I just bought a new fuel filter...and it came out of the box with a big dent in it...I could take it back it was 38 quid or stick it on...but will it reduce flow ?
Post #369351 4th Nov 2014 12:41am
