Home > Technical > Grease guns
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Grease guns
I have 2 grease guns which I use for servicing prop shafts on defender.
I have never been happy with the figment of the grease gun nossel onto the grease nipple as I don't find it seals well and grease end up going every where but into the universal joints.
I did chAnge the grease nipples on my UJ's for the extra long ones from G lewis but despite this still have problems with them not sealing or not being able to remove gun from nipple without unscrewing the fitting itself Twisted Evil
My question is am I using the wrong size adapter on my grease gun? It here a specific size or make that works well?
Thanks in advance Thumbs Up
Post #364531 14th Oct 2014 11:04pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
You could try changing the nozzle on the grease gun as some nozzles don't always work and some do, i find with my grease gun it will grease the rear prop no problem but when trying to grease up the front prop the nozzle touches the UJ before it fits onto the nipples so have to resort to removing the prop to grease it Big Cry Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #364545 15th Oct 2014 12:26am
jimbob7
I use a cheap £10 Silverline grease gun,goes on easy enough, a bit fiddly detaching it but has a good seal and doesn't leak. Pov.spec,ftw. 2006, 110,TD5.
Post #364546 15th Oct 2014 12:27am
Happyoldgit
I have several grease guns but my favourite for greasing prop UJ's is the one which I have fitted with a flexible shaft and ground two flats on opposing sides of the nozzle itself. Steve.
http://forums.lr4x4.com
Post #364566 15th Oct 2014 8:01am
Anderzander
The state of the UJ's makes a difference - if the are solid with hard grease - then with the new stuff taking the line of least resistance, that may be the seal on the connector.
Post #364575 15th Oct 2014 8:28am
x-isle
This is the one I use that is perfect on the UJs. The flexible hose means I can get on the nipples and the fitment is tight enough not to leak.
http://www.ebay.co.uk/itm/Hilka-Pistol-gri...2a2ffdf1df Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #364634 15th Oct 2014 1:02pm
kipperthedog
Warming the grease in the Uj with a hairdryer/heatgun can help with the displacement of any old grease.
Post #364709 15th Oct 2014 6:53pm
amondeggs
Thanks to all for the comments Thumbs Up
The UJ's are an area I don't neglect, I tend to remove props at least once a year sometimes twice. If I find any play then I change the UJ's. I always use gkn one as the quality is good. As explained the only issue I have is regreasing so that I get grease coming through each of the bearing sets.
X Isle thank for the tip I think I will purchase one of those guns Thumbs Up
At least I know that it fits and does the job
Thanks again Thumbs Up
Post #364735 15th Oct 2014 7:49pm
Retroanaconda
This.
I had similar issues the first time I tried to grease props, consulted a friend with many years Land Rover experience and his advice was to grind the tip of the gun down slightly. Did that and it's been fine ever since, works a treat Smile
Post #364741 15th Oct 2014 8:06pm
munch90
cheap guns have cheap ends
Wanner are a good make , used in aircraft industry
Post #364742 15th Oct 2014 8:08pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I use an old grease gun probably my granddad has used it already. The strange thing is that you just push it against the nipple. If you the continue pushing the body off the grease gun in the direction off the nipple the shaft is pushed in the body and the grease into the nipple and it hardly leaks any grease.
Because it doesn't have to go over the nipple the head is small. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #365053 16th Oct 2014 8:53pm
