Home > Puma (Tdci) > Rattling and Chirping window panels
Bionicmunky
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi All,
My side window surrounds (TDCI 90 CSW) have started rattling and chirping when going over bumps. I guess the clips have loosened off, especially since the dealer removed the surrounds a couple of time when new.
A couple of questions:
1) How do you remove the surrounds - I plan to do some general all over sound deadening.
2) Any better way of securing them when refitting?
Thanks in advance
John
Post #364503 14th Oct 2014 8:53pm
Bionicmunky
anyone?
Post #364901 16th Oct 2014 11:55am
Cheshire110
IIRC in my 90 you had to remove the seatbelt hanger with a big spanner, wasn't too tricky i don't think. Cant remember what held them in at the rear end. Cheers, David
Post #364925 16th Oct 2014 1:00pm
CARMARK2014
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
My puma window rattles over dumps, I took the door card off to find the 2 rail the window run down when were loose but its that tight on space I couldn't fix then I couldn't see how they are supposed to be, but this could be the same as mine. Defender 110
Post #364930 16th Oct 2014 1:12pm
dgardel
Italy
I solved with this (only the bottom one)
http://www.mudstuff.co.uk/garrison-sw-rear-window-kit.html
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #365048 16th Oct 2014 8:37pm
