![]() | Home > Technical > Clutch |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Hi, MK!
Mine do the same, and I had my clutch replaced 10000 km ago (with 25000km), I think it's normal, but still don't ask my dealer about it, and it didn't do all times, so I think it's normal, waitng a little more time with clutch depressed may help, but not solve, and lets remenber that is a Defender, everything is possible!!!! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Hola
NFWay I´ll leave it as such. Puma 110" SW ............................................................. Earth first. Other planets later |
For those mechanically wised, what could be the issue with Defender`s weak clutch?
Plate Size? springs? pressure plate? I know the 1st generation had problems with the springs, but I´m trying to find out why the 2nd type sometimes also fails. cheers MK Puma 110" SW ............................................................. Earth first. Other planets later |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
1st service next week for me and some warranty work. I mentioned the clutch and I do believe they are going to replace it. Question is will it be 1st or 2nd generation on a 2010MY
![]() 55 TD5 110 CSW Special Vehicle |
in this forum there is a pic of the 2nd type. Also ask for the part number they will use. Puma 110" SW
