![]() | Home > Td5 > Exhaust Smell |
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
Look at the passenger side foot well from the engine bay, there is a 2 inch hole that the aircon pipes would run through if it was fitted and that is a common place for engine bay smells to get in the cab.
Pete. |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Exhaust manifold can warp leading to exhaust leaks (look for soot stains around manifold to head joint) can be accompanied by a whistle/screech at high boost. 2005 Td5 90 XS
Steve |
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 443
Thanks for the replies. When the rain stops here I will go have a look
Cheers |
| Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271
Check there isn't either a hole in the exhaust along the mid section and that all the joints are done up properly too.
