Home > Puma (Tdci) > Help and Advice please. Cooling problem. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
2010 MY Puma 90, 52000miles. About 4 months ago the thermostat failed and was replaced. All well for 3 months then happened again. Indi admitted they had fitted a Blue box replacement so fitted a genuine part this time at no cost and apologised.
However, temperature on Scanguage now goes upto over a 100c and eventually the dash temp goes up and limp mode. If I drive at 50mph in 6th temp starts rising, change down to 5th, same speed but more revs temp goes down to 90c then gradually creeps up, change to 4th, same speed but revs now 3000 and temp goes down to 82c and then gradually rises, change to 6th and temp goes down to 90c and so on. When the temp is falling internal heater is blowing hot, but when temp is rising it is blowing cold. I'm thinking 1. Airlock 2. Viscous fan not spinning at correct speed, just idling or inertial drag but not engaging full drag. All coolant pipes pressurised when engine running. Engine running well, no leaks apparent except when really hot, limp mode when pressure cap does what it's supposed to do and releases pressure plus some fluid. Has anyone got any advise please, I'm desperate to sort this problem, and thanks for any helpful advise. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
5th Oct 2014 4:49pm |
Thanks munch90. So it is unlikely to be the viscous fan. Airflow through radiator fine, never been off roading in mud etc, just farmers tracks and camping fields.
If there was a head gasket leak would this just be one way, ie gas out only into coolant? Did 200 miles on Friday, temp upto but not over 100c on Scanguage, but that was leaving at 5am and with heavy traffic. Today, same trip in reverse, warmer and no traffic congestion and this time temp did go up, limp mode and pressure cap did vent. Cap holds pressure, but as you say it may not be correct pressure! Back to Indy tomorrow. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
5th Oct 2014 6:45pm |
just get a cap from motorfactors or even Halfords and try it , you maybe lucky , fingers crossed etc
I know what you mean , you would think water should go into cylinder and lose water , but not always the case |
5th Oct 2014 6:53pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Could it be the water pump impeller slipping? I have heard of them spinning on the shaft. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
6th Oct 2014 9:14am |
impeller problems common on vw and bmw , cant think of the ford engine doing it , but possible
one ford engine that had a problem bit like it was the front wheel drive transit but that was the spline driving the pump |
6th Oct 2014 9:50am |
Well today, behaved properly. Temp went upto 91c on a hill, after 8 miles of country B road then promptly dropped back to 85c.
On way home, much warmer stayed between 85c and 90c, except after accelerating up a hill in 2nd and 3rd when the Scanguage momentarily jumped to 102c then promptly dropped to 85c. Heater working all the time, but cools when idling at lights. No change in water level. I'm erring towards an airlock following the thermostat change, the airlock having been disapated in my trials and tribulations on the M6 and M4 yesterday. Fingers crossed. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
6th Oct 2014 8:21pm |
